FJ Strut/Coil?
shannon45
I have found a lot of info. on replacing my X Reas with FJ suspension and wanted to know if I install OEM 08 FJ front struts/coils and rear coils will that give me any lift or will I need spacers on front and rear? I thought I read that it would lift it about 1" but just wanted to make sure before I took everything off and then find out I need spacers.
I think that just the springs and struts from a FJ with give you lift. I just seen a set in the classifieds for $350. There is a whole write up about the FJ suspension upgrade.
If they are 4x4 FJ springs then yes, you can expect about 1" of lift if you have a V6 or about 3/4", possibly a little less if you have a V8.
CoaterZ_FL
