Flat Towing
USMCYota
Is it possible to flat tow a 2WD 2006 Toyota 4Runner Sport with an automatic transmission behind an RV? I'm hitching a ride to Texas in my in-laws RV and don't want to rent a car when I get there.
Some tranny's won't work flat towing as the transmission fluid pump won't lubricate the gears while moving. I'm not sure the specifics on the 4runner but i know most fwd tranny's don't handle it at all. I would do some more research on this one. I'm just not sure.
Is it possible to put the truck on a trailer? This still creates wear and tear on the truck and puts miles on the odometer.
This is a valid point. If you reference your Owner's manual it shows diagrams and instructions on how to properly tow the vehicle. You will have to tow the vehicle with the front wheels in contact with the ground and the vehicle in neutral or on a flatbed. Otherwise you can damage the transmission as the fluid pump will not be functioning.
Not to be a jerk, but all this info is in the handy dandy Owner's Manual. :)
As Blackworks and setty said, the pump is not on you will over heat the transmission.
You could pull the drive shaft if you really needed to tow it flat, but that could be more of a PIA than it is worth.
The bigger issue is a tow bar. Unless you have an aftermarket steel bumper, you are not going to be able to attach a tow bar very easily or cheaply. You would probably spend more in getting a tow bar to work than it would cost for a trailer rental, and both of those would probably cost more than a rental car.
Rent a car. Honestly. With hotwire, you can rent a car in most places for 20-30 bucks a day. If you need insurance, take on 10-20 bucks.
It isn't worth the PIA factor of trying to tow a SUV just to drive. Hell, the difference in GAS your parents pay to tow will about cover it. I am assuming this is a huge RV if you are considering towing it, which means a gas hog already... but over the mileage you are talking, towing several thousands pounds will add up in extra gas.
Plus. Pulling the drive shaft, being concerned your parents take a corner too sharp and scrap the **** out of your truck (happens!)... it isn't even worth it.
Final note. Don't tow in N. It is really bad on auto transmissions. Most people I talk to also comment that it is still moving the gears in the tranny, if even just the final, and without the pump on to move/cool the fluid, heat is going to build up. How much? I have no idea, but most people I know suggest it isn't worth the potential wear and tear.
That leaves car trailer (added expense) or butt off the ground, towed on front wheels. That adds wear and tear on the front suspension, as at that angle, more weight (different balance point) is riding on the front.
My personal opinion? Unless you are moving, and you just HAVE to get your truck out there.... the cost of a budget car rental is worth not worrying about all the crap you have to worry about to tow a car.
youngrk
