Thanks! I'll try cleaning the contacts and if that doesn't work I'll replace the bulb. Was the bulb easy to find or did you need to order it from the dealer?iFORCE said:Happened to me too.. I just replaced the bulb and everything is fine. 10min. and 5 bucks.
guide to taking apart your dash.
http://www.castulucci.com/projects/carpc/oemnaviaccess/
benhar said:Thanks! I'll try cleaning the contacts and if that doesn't work I'll replace the bulb. Was the bulb easy to find or did you need to order it from the dealer?
I poked around Partznet but didn't see the bulbs. Did they come from the dealer or another website?iFORCE said:I"m thinking that since it goes in like a screw... it might be loose. The lightbulb comes with the plastic screw on piece..(you'll know when you see it.. it's beige) anyways, it was a special order and it took 2 days to get it in. Dealership wanted to charge me CAD$90 for parts and labor.. so I went and spent 5 bucks, 15min. and did it myself.
if you don't want to do this anytime soon for the LCD display.. buy two bulbs and do em both!
benhar said:I poked around Partznet but didn't see the bulbs. Did they come from the dealer or another website?
Thanks for your help!
Oh ok, I'll check the dealer then. I was just suprised you could get something out of a car dealer's parts department for under 10 bucks!iFORCE said:dealer.... partznet isn't going to stock these things. You're not going to save much on a $5 bulb assembly but buying it online.
LV4R said:All I did to fix this was lift the little wires on the bulb assembly that contact the unit. This fixed the problem for me.
