Fluids
YZThumper
Could someone please indicate which fluids I should use for the
1) Tranny (what came from factory, since I'm just doing a drain & fill)
2) Transfer Case
3) Differentials
on an 03 V8 4R
thanks a bunch
:cool:
Does your transmission have a dip stick. I have heard that the change to the new transmission fluid was near the end of the 03 year. It makes a big difference.
1)Tranny
Toyota ATF type IV about 4qt for drain and refill
2)Transfer
75-90 Gear Oil Mobil 1 Synthetic is what I recommend
about 1.5 qt for drain and refill
3)Diffs
75-90 Gear Oil Mobil 1 Synthetic is also what I recommend
1.5 qt front diff 3qt rear diff
front diff need 10mm hex drive for refill and drain plugs
