fog lamp upgrade/retrofit?
01thunder
i have been looking for a factory set and found them.
now, i want to replace the factory bulbs and install something better/brighter. what can i get for them? what size bulb are they?
H3 bulbs. There is write up on here about adding HIDs to them, but it is a good bit of work. I went with Hella Optilux at first, but they burned out quick. The second time around I went with a long life Hella H3 and everything has been good so far, but it has only been a few weeks.
clear or yellow? there doesn't seem to be many options for these. i looked for the threads but didn't find info i needed.
adding HIDs takes an hour tops. Its not hard, but the beam pattern is worse than halogen in my experience.
I ordered the hella micro HID projectors
The optilux I started with were yellow, but burned out quickly. The ones I have now are a regular white bulb.
The only part I didn't like about the HIDs was that you had to cut the stock wiring. That's usually what happens as well when adding HIDs to a set up designed for halogens, the output is worse. I wish my yellow bulbs would have lasted longer, I really liked the yellow light.
I just cut off the old plug from the old lights and soldered that. No change to car side wiring.
i noticed that on the cover it says H3 or H3A. is anyone running or has anyone run the amber H3's for fogs? what brand? light output? longevity?
The hella optilux I mentioned are amber. Longevity was not good but I liked the color alot.
BillM777
