Fog light issue
FrankA
2003 SR5, v6, 2WD. I can’t seem to get my new bulb on the passenger side to light up. Is there a fuse associated with this bulb that I can check out?
Thanks for the input.
Yep, there should be a fuse for the fog lights. Just pop open the fuse box and find the one for the fog lights. If the fuse looks good, maybe take a peek at the wiring and connections. And, of course, make sure you've got the right bulb and it's snug in there.
I would check for voltage on the connector with a volt meter. Some of the connector pins get weak after awhile too.
now, you didnt say if your using regular bulbs or hid or led. if you did use either hid or led, just reverse the way you plug in the light. the connectors on the 4runner is usually reverse polarity.
tuṣṭāva
