Fog Light Lens broken
oldlures
2013 4Runner. Rock hit the fog-light lens and broke it. The fog-light itself still works. Anyone know if where you can just purchase a new lens? I hate to think about removing the front bumper and installing a whole new assembly when this should be ab under $10 fix by simply gluing on a new lens. Local dealer couldn't (or was interested in) help. I've tried searching just for that part but no luck.
I have one that continually filled with water. Even mid summer with 90 degree temps it was full of water. I ended up buying a new one off ebay.
The lens is sealed to the housing. I have no clue where the water was coming in. Once I swapped in the new unit, I dried out the old one and cleaned it up. It looks okay, but again, not sure how the water was getting in.
Anyway...ebay, amazon or you can buy my leaker for $20
Yeah, I tried prying off a lens from a broken assembly that was given to me. No go as the lens instantly cracks with any kind of pressing in trying to pry it off.
You have a used set of JUST the Lenses which this post is about right? I do not need the entire assembly
go for a complete assembly. you don't want to mess with the factory seal if you don't have to. Pull the bumper and swap the housing... 45 min job tops.
