Fog Light Mod
SCRunner
I have been reading the forum for a while trying to figure out whos advice to take about how to turn on the fog lights without having to turn on the headlights. I finally just kinda did what RXvedub said in this thread , and it did exactly what I wanted. I tied the jumper to the green wire for the driver's side parking light to supply the ignition-on power for the fogs. The lights come on without the headlights having to be turned on, and they go off when you turn the ignition off so you don't kill your battery. I still can't figure out what the point of the whole steering column jumper wire was supposed to be, but I don't see any need to do any more wiring. Thanks for the advice!!
Photo_021207_005.jpg~original
daylight
Photo_021207_009.jpg~original
Photo_021207_008.jpg~original
night time
daylight
night time
Did you have to do the little pig tails on the pin?
The first thing I did was make the jumper with a little bit of 18 guage wire and a crimp on "quick release" spade adapter on one end. After you bend the correct pin out and up on the fog light relay, you just plug the spade adapter onto the pin and run it to the parking light positive wire (green, I hope!). It was actually very easy, surprisingly. I think that all of the pigtails that RXvedub put on there were an attempt to clean up the install, which really doesn't look messy at all if you tuck the wire around behind the battery
sounds good, that's what i was trying to figure out if i needed to do all of pig tails, it just seems complicated to me:biggrin2: Thanks and great job on the mod, i will try this when i put on my intake.. :bigok:
Nice Job.
Correct me if I'm wrong here please.
So after this mod, everthing should be the same only now that the fog lights can be turned on without turning the headlights on?
Correct :D That is all that I was trying to do before, and was so confused by everyone arguing about this and that, that I couldn't figure out what needed to be done! Hope that this helps out. I'll take some pictures of exactly what I did tomorrow, weather permitting, and put them up here.
Just a free bee for 2006 - 2007 model owners if you are planning on doing also the steering colum one to keep the fog lights on with the high beams (correct me if I am wrong), the wire colors are different (white w/black stripe and red with/green stripe), or pin # 2 wire and pin # 17 wire for sure.
Good luck.
:bigok:
Good luck.
:bigok:
Ahhhhh! That is what the steering column step is for! I couldn't quite figure that one out. Thanks for the clarification!
Good luck.
:bigok:
Here is the link for better visual explanation on both modifications. I like better the mod from kmvreter is cleaner looking........just my personal opinion but you have both mods to pick one.
http://www.toyota-4runner.org/showthread.php?s=&threadid=8435&perpage=15&pagenumber=3
