fog light retrofit (Finally Done!!) pics on page 2
more pics
more pics
extra pics
extra pics
How did yours turn out? I'm interested to see how you mounted them
Dude. Yours look sick. Mine aren't as professional. I just took out the fog light housing and drilled holes to bolt and tie down the aftermarket ones. Here's how they turned out
Sent from my SM-N960U1 using Tapatalk
Thanks man! and yours turned out really good too. These were the perfect size for our 4runners
do you or anyone here known if these fog lights fit my 17 4runner limited? I bought the custom headlights from hidretrofitkit but planning to get custom fog lights too. Also those led halo rings are just white color or they change colors too? Please advise, thank you.
I don't believe so because these are almost flat and the 17 4runner fog lights are pretty slanted. If you want to use these I would take some measurements of your oem ones first to see the size. These are 3.78 inches in diameter. If you arent wanting to do any fab work, morimoto makes a similar fog light for the 17 4runner.
https://www.carid.com/morimoto/proj...n-lf220.html?singleid=1209888249&url=89195738
And the halo rings on these are only white
They look great, but what are you doing for thermal management?
Thanks! and when I had to feed through the 9006 connector I had to drill out the back side of the housing. This also served to allow heat to escape and cool air to enter.
After a lot of fiberglass, drilling, sanding, painting and test fitting, they are finally complete. The pictures don't do it justice at all but it looks amazing
Nicely done OP, definitely took the time for a professional install.
Do you have any pictures oh how you installed yours [MENTION=96696]Samm25[/MENTION] ?
I don't have any photos of the installation but I'll tell you it was ghetto, Haha. What I did is removed the entire fog light housing, the one John used to cut and place the new fog lights in, I just removed it entirely and with the big empty slot it leaves, I drilled a few holes on the side and used zip ties to tight that shh down. Like I said, ghetto, but they don't move at all and it saved me a bunch of time.
I'll try to grab some pics and put them up later today. If I had the time and tools I would've had John give me an entire write up of how he did his because it looks much more professional haha
I did that before and they’re a little blinding and the light output is spread all over the place. They don’t necessarily give out that nice clean cut for LED bulbs, they’re just bright. Once the OP posts pics of how they turned out for him, you’ll see. Trust me.
I just swapped the bulbs to LED and had no issue....Amazon/ebay LEDs are trash....If you want a good site let me know
utkrstam
