Found Leds that work DRL/High Beam
rayofsi
https://www.amazon.com/gp/product/B01M3SHYS6
i was debating ddm or not, bought these to try.
they work. DRL is dim, with some flicker. High beam is bright! half the price of ddm. and easy amazon returns
These appear to be about the same as a hikari brand that is on amazon as well.
Will update on how long these last till they die.
I'm glad you found something that works for you, but this flicker is exactly what every other LED in this position will do (run at full HB brightness with flicker). So far, there's nothing on the market that truly works how an incandescent bulb would in that DRL / HB spot.
I'd be willing to bet just by the name and price that those are pretty cheap Chinese LEDs I'd be curious to know how long they hold up. My bet is that their price matches their quality.
this RUNS DIM.. with a slight flicker in DRL mode. and BRIGHT in high beam.
LOL... look at the word "ASLO" = ALSO in their add!
You know they are China made....
A lot are made in China, but they could at least have used psell hceck!
That's exactly how every other led in the high beam position works..........
most leds.. are full brightness in DRL mode? at least that's what all the theads say?
Which other leds asides from the ddm saber will run DIM in drl mode? Please link
Please do share the Morimoto part # that runs dim in DRL without flicker..
They still flicker a little bit, only noticeable when parked a couple feet away from a wall. Like many have said before, I am pretty sure all LED function this way when used as DRL/Bright combo unless you use canbus. But then your DRL are in full bright mode, which I didn't want to do.
Clearly they were referring to Association for the Sciences of Limnology and Oceanography (ASLO).
i am looking for DRL but want to make sure there is no flickering
I have DDM low beams and Fog lights
any issues with the DDM DRL? thanks for your help and did you go with 35w or 55w
