frame swap help
found this frame about 2 hours away, i called and not much detail on it, asked her if it was in a collison says she believes it only lit on fire. would this work for a frame swap??
Yea that looks good - at first I was all sort of confused - what is that I front of the crash bar and then I see it’s a bull bar that’s toast. The radiator support looks clean
It’ll be a ton of work to swap, but assuming no other issues with that donor - looks like it might be worth th drive to see
the vehicle is in a co-part facility and can only be purchased through online auction; which in Florida you have to have a license to do so. So not running into any luck on much information on it, as have to have this and that to even look at it.
[MENTION=149207]AuSeeker[/MENTION]
The transmission crossmember is different between the V6 and V8. I have had them both on the floor togethe. The V6 is taller, but they both bolt into the same place and are interchangable on the frame. The 4WD bolt in too.
