Free 2010-2021+ Extended Fuse Cover 3D Print Files
ihateu3
I'm sure a few of you have seen this cover develop on a couple of other threads here. To organize everything into one thread, I am making this thread here. Thanks to [MENTION=200736]ElectroBoy[/MENTION] for the pics, and his review of the cover here Extended Fusebox Cover for 5th Gen 2010-19.
These files are provided for free for personal usage, and are meant for the forum community, selling prints made from these files is not permitted.
All files have been uploaded to both Thingiverse and Google Drive for redundancy.
Be aware that 2020+ 4Runners have different covers, both are available below
You will want to print this cover in ABS to withstand the interior automotive temps. I have also provided a link to my store if you do not have a printer, or are unable to print in ABS. You can also directly message me if you would rather do that instead of my store.
3d printer file links
2010-2019-4Runner-fuse-coverV3.zip - Google Drive
2010-2019-4Runner-fuse-coverV3 - Thingiverse
2020+-4Runner-fuse-cover.zip - Google Drive
2020+-4Runner-fuse-cover - Thingiverse
Store listing
Toyota 4Runner 2010-19 Extended Fuse Cover | Etsy
Toyota 4Runner 2020+ Extended Fuse Cover | Etsy
Ordered. Because my friend with a 3D printer is not reliable. Thank you.
This is awesome! Does it come with the diagram too?
Yes, on the thingiverse link, the diagram is in one of the pics, so you can download it. If you use the Google drive link, the diagram is included in the zip file, and if you purchase one from my store, the diagram comes attached to the cover.
Thanks for this! Appreciate the work you put in and making it available to the community. Ordered via your Etsy. :cheers:
Received mine in the mail yesterday! Ordered directly from ihateu3.
ElectroBoy has a pretty in depth review so I will not get into specifics. It is well built and secures well to the fusebox. Highly recommended if you have fuse taps and do not have a cover!
Thingiverse link is coming up as a 404 for me - anybody else?
Thingiverse link is working for me, but Thingiverse is not reliable. That is why I also put the Google Drive link up, it is the same exact file as on Thingiverse, only more convenient since the fuse diagram is already inside the zip file, instead of having to download the picture on Thingiverse.
If you plan on making on for a 20 - I'll be your 1st buyer
I am not a 4Runner owner, and this current cover exists because I made a cover for my 3IS Lexus, which to me looked to be exactly the same cover as the 5th gen 4Runner, so I shared my work here for others.
What I did not know at that time, was that it was the 2020 4Runner cover that I had seen, and it happens to be different than previous years, so my provided 3IS cover did not work. I then felt bad providing a non-working cover, so with [MENTION=200736]ElectroBoy[/MENTION]'s provided measurements, I modeled up a cover that worked for the 2010-19 4Runners.
This still leaves me with the original 3IS cover that I believed to be the same as the 2020 4Runner, but have yet been able to verify. If you would like to try this cover, so we can verify the fitment, go ahead and message me and we will figure it out.
Ordered through Etsy! I'm happy this thread showed up. I was planning to just leave my fuses uncovered since I have a SwitchPros trigger line coming out of there but this will clean up the install very nicely. Thanks!
Sent from my Pixel 2 using Tapatalk
Same just ordered so I can put a cover back on.
Thanks to ihateu3 i was able to print of these the other day. I used Diran as my material since its what i had available. If you can see by my pictures, i have my add a fuse's pretty close to the edge on my fuse box, this makes it a little harder to get it off and on, but the cover is still light years beyond not having anything.
The 2010-2019 version thingiverse link goes to a 404.
I am not sure what is going on with that. If I am logged in to thingiverse, the link works, but if I log out and try to use the link, it gives me a 404 as well...
There is also a Google Drive link in the OP, that is the same file, and the link should work.
perarenato
