Free 2010-2021+ Extended Fuse Cover 3D Print Files
Any chance of a fuse cover for the one under the hood?? :)
An extended cover? One of the issues I would have is getting accurate dimensions so that I could model it since I do not own a 4Runner. Another possible issue is if it is quite a bit bigger, it would cost quite a bit more, and I would have to make sure that it fits on my ABS printer.
Thanks @ihateu
I received my cover today with the label for my 2021.
It was well boxed and looks good.
I made some modifications to it for fitting purposes of my now and future add a circuits. I cut one corner of where it fits next to a plastic support.
I removed the OEM label and placed it on the new cover!
Photos supplied for others to see the quality.
pnJ1pkgFj
pnZQOJNVj
pnfbhTzwj
pnoFH8VAj
OEM LABEL INSTALLED
pnuEaQH7j
COVER INSTALLED!
pmlSAliSj
Thanks,
I need to try and buy some glossy labels (if they even make them), to see if they print better. I put these labels on kind of as a bare minimum afterthought since I initially was just trying to give the files away for people to make their own, but then ended up offering to print them for those that do not have a 3d printer or a capable 3d printer. The hardest part is 3d printing them, so I figure if I get them the print, the label would be easy enough to swap if needed or making a higher quality label is within anyone's capability.
I pretty much expect that someone will put their original label on it, but I put these on just in case, as they are still useable.
I found some glossy labels, and printed them out. They look much better than what I was slapping on them. I will start using these.
We have a 2021 and I would like to get one of these covers but it says sold out. Are there plans to have more made?
You missed it. There was a run on Etsy about 6-8 weeks ago. I managed to grab one then for the 2020+ and they sold out rapidly.
Hey guys, sorry I have missed some of your messages here. I have been pretty busy lately. Just checking in to let you know that I am still here, just not as often as I should be lol.
I’ve been using and liking your 2010-2019 fusebox cover. I see you changed your 2020+ version to add a fuse storage compartment using the original Toyota cover. Do you also offer that option for the 2010-2019?
Hello
I tried to use the files but the image is very small. What are the size parameters?
The cover is modeled in inches and needs to be converted to metric.
Yes I do, here
Toyota 4runner 2010-19 V2 Extended Fuse Cover - Etsy
