Fridge Slider Install Questions
shoong
Member
Hey All,
I have a SetPower AJ50 and I'm planning on ordering the slider for it. I have a few questions as to how to mount it to the cargo area of my T4R.
Why do some folks mount/bolt it to a piece of plywood instead of mounting/bolting it direct to the T4R?
If you are mounting/bolting it to a piece of plywood, are you mounting the plywood directly to the T4R then the slider to the plywood?
If needed to drill into the T4R, how do I go about it? I don’t have a sliding cargo tray.
you will find out you need to drill the sheetmetal which means the underside will be exposed to the elements . yes the plywood is mounted to the sheetmetal on existing holes - these holes will never line up to your slider. there is a reason why people mount to plywood - you should look to do the same.
I plan on installing a fridge and here are some good options that my research came up with:
Sherpa Baseplate
Toyota 4Runner 2010-Present 5th Gen Rear Plate System – Goose Gear
AJC Gear Plate for 5th Gen 4Runner (Non-3rd row/Non-Cargo Tray) – Aiden James Customs
I plan on going with Sherpa. Goose is $$$ and AidenJames doesn't seem to have the best reviews when it comes to customer service.
thanks for this. I didn't know sherpa made base plates and it's pretty reasonable. I priced it out and it's not far off if I was to do it myself.
I have a sherpa rack and love them BUT read the fine print:
5th Gen 4Runner
- Requires drilling and bolting through the floor
- Does not fit sliding tray models
Wont work with sliders and drill through floor (?!?) ... drilling metal should be a no-no.
The AJC is is the best choice IMO. It is 100% reversible (no drilling or cutting).
Goose is also no drill, but will require you to remove the carpet & underlay, which will make your vehicle noisier.
charlesz
