PlugKnocker
2005 4runner sport edition.
150k
V8 2WD 17inch wheels.
Front change only. (No rear work)
Replaced Pads and Rotors.
When test drove short ride 3 miles. Brakes were hot on return.
Lift the front wheels they would not roll/spin. Could not move.
Took back apart removing pads double checked the work. All was correct. Reassembled the brakes again. Rotor turn but once the wheel is tightened down. The wheel seizes up and will not turn free spin.
Called Auto parts. Took rotors and box back to check and they were correct parts (O'Reilly's)
But suggestion trying a different rotor only 12.5 IN OD.
Install the 12.5 Rotors and same pads. Rotor turns and pads are installed. Mount wheel and it will not roll/rotate at all.
Very irritating since many times now off and on.
Last choice.
Put ALL the old parts back on. Rotors, old pads, Mount wheels and guess what.
The wheels roll freely. I think I have another 20k on these pads.
Any suggestions you can offer. Since I still need this done.
What caused the new Rotor and pad to seize the wheel?
Thank you
150k
Last choice.
Thank you
