Front diff replacement drain plug PN?
bugman-74
Member
Looking for the part number for a replacement front diff drain plug for a '99. Mine currently has the 12mm hex key, and has seen better days. Understand the "new' version may use a 10mm hex key. I dont think the "common" 90341-18021 magnetic plug will fit the front diff drain location... Anyone know the correct part number? I would also like to confirm the crush washer PN is 90430-24003.
I just went through the same thing as you. Ordered a new one from local toyota dealer for $20 after tax. Then got a smarter idea and took stripped plug to local shop who welded a 17mm nut on it for $10. Canceled toyota order and glad i did.
now it is beefier than ever and i never have to worry about it stripping out again.
Just something to ponder.
Thanks for the info guys. I confirmed with the dealer that the drain plug is #90341-24014 and crush washer is #90430-24003.
Jhunt
