Front Driver Seat
spartanrun2015
Dose anyone know where I could find a new front driver seat? Driving more then 4 hours starts to hurt the body after a while. So I'm wondering if a new seat will help..
I had a similar issue with my driver seat, which was at 315,xxx miles. The local dealer had the back and bottom foam cushion so I replaced them both while adding inflatable lumbar and a bun warmer. The new cushions are firmer and place the lumbar in the right spot on my lower back. So, that might be an option for you.
search craigslist for "4runner part out," you may be able to find a newer seat there. or try the dealer. does yours have lumbar support? after a day or two of owning mine i felt the same way, then i realized there was a lumbar support. so much better.
The foam is the same for driver and passenger side (at least the bottom). If you junkyard shop, find a passenger seat. They are usually in better shape.
is that the little button that you push on the side of the seat the blows air into it?
The Lumbar in our seats (and I think in Toyotas in general) are mechanical, not pneumatic.
Honestly I'd get a quote form a good upholstery shop, if you're the primary driver of the vehicle you might just want to have them quote you for a custom cushion job that best fits you; shouldn't be too expensive from what I hear (a few hundred dollars I think last I heard? but then again a new seat is bout $1200 or more from Toyota, a used one that may or may not be in good condition and not stained with god knows what might be a couple hundred?).
I am thinking I may go this route when my seat wears out a bit too much, I've hear the people that have done it find the difference to be significant. If you're a bigger guy they can put varying density of foam in that will support you better than a factory seat could since it's all one type of foam.
I had a custom upholstery shop do mine and it was about $200 for full foam and another $200 to have them custom sculpt it to my back so it fits perfect.
Close but no cigar! A motor in the back rotates which pushes the lumbar piece forwards or backwards. The pneumatic lumbar piece I installed has a lot more travel so the effect is more pronounced.
AndiGarage
