front end sagging problems
T4Ralabama
My 1998 sr5 4x4 has a problem with the drivers side sagging put in new struts this weekend. It was level until it settled (in less than a day) the right stayed up but the drivers side is still sagging. Is it the coil? Could my A-arm be bent? i need an alignment could that have any thing to do with it? I need the wheel adjusted cause it also has some toe out (which i know can be adjusted and I can do) Ive never had a wishbone IFS Ive always had solid axle jeeps, its all new to me so what do I do? Any things is need to look for? Any ideas and advice thanks!
another thing to look at is your end links and sway bar bushings. When mine broke I got a little lean effect also. Not sure if this could be your issue but is something else to check. Also not likely to have bent an A-arm but bushing could be bad also which would contribute to the alignment issue. If you have jumped your truck at all then another possibility is your spindle could be bent.
ive never jumped it but the last owner...:lookout: welll wouldnt have surprised me if he did that lol ill check all of that thanks!
