Front factory skid plate rusting off! Replace??
Jeff T
Member
It's the large piece under the radiator. It's just rusting apart. I'm probably going to take it off this weekend, any reason to replace it?
Besides protecting the oil pan it also serves as a splash guard to help prevent water from splashing up onto engine electrical components.
I'm amazed it's rusting away. My 05 4runner's skid plate is fine....no signs of rust what-so-ever. And while this last winter here in NH wasn't bad...the previous 5 years were.
Have fun getting the bolts out that hold the skid plate on. My 03 had 100,000 miles on it when I removed the skid plate and I managed to bust a bolt head off.
Good Times!
I took mine off and sand blasted it so it could be powdercoated. The metal was so thing that blasting the rust off left me with a ton of holes. I replaced it with a Mano-o-fre skid and really like it.
This one?
My 4Runner is an '03 bought and driven in New York for a while. I live in Oregon where the roads aren't salted. I've got some rust to deal with underneath. Other than the under carriage, for 100K, it's very clean and all the major maintenance was completed. I'll be using POR-15, wire brushing and replacing bolts.... not looking forward to it.
I do like that skid plate, but it'd be a hard sell to the wife since I'm lifting it.
I have seen probably 30 4runners in my quest for the one and MANY of them had substantial rust. If I could offer some advice, get some access to some air and a wire brush attachment for the craftsman equivalent of an air powered dremel (I have the part # Ill have to get it later). Take a day and scrub ALL of your undercarriage rust off and spray with some undercarriage anti-rust paint. Toyotas HATE salt and that rust will just eat her to pieces. They had a recall on 99-ish Tundras for corrosion issues and my Dad has his entire frame replaced. If you are in the salt belt, give her a scrub, and coat of anti-rust paint. It will make the truck last longer.
Cheers!
I tookmine off, cleaned it with POR15 "marine clean", prepped it with some other treatment they sell, then 2 solid coats of black POR15! Looks damn good!
Jeff
I have the Man-A-Fre and am very happy with it. It is thick steel, inexpensive, and just looks tough. Come by if you want to see it.
Rockwall
Jeff
Rockwall
Does it have the hole to access the oil pan drain, or does it need to be removed???
Anyone!!
My 2004 continues to rust away... Front skid plate was gone a few years ago with the muffler heat shield. The other day the plate under the oil pan started flapping... When I went to remove it I noticed the protection around the fuel tank is about 30% gone as well.
12 years of no garage are starting to catch up to my old girl, but they have been some of the best 275,000 mikes I've ever driven!!!
My 04 V8 lives in salted CT all her life and the front, fuel tank and exhaust plate are all rusty through. That's why Google brought me here.
Should I replace them or just took them off?
Jhunt
