Front lift opinion/help needed
Good351
So I have a set of the Bilstien 5100's on order. I only want a slight lift to the front to get closer to level, so my thought was to install at .85 with the stock springs. Then I read about the Taco springs.. The taco springs do look beefier.
I only want around 1" of lift and nice smooth ride.
A. Bilstien's set to .85 and stock springs
B. Bilstiens's set to 0 with Taco springs
And if Taco springs..Which ones? TRD Off Road (progressive) or TRD Sport (linear)
If you want to maintain stock-like ride, then use your stock springs. A stiffer spring is, many times, desirable if you are doing any significant lift or any other situation where you want to reduce body roll, reduce front end dive, or are using a heavy steel off road bumper.
I agree with Mark. The Bilsteins are great shocks and a good choice for your situation. If you want to level your vehicle, but keep stock ride, go with spacers instead of new springs.
