Front spacer height questions
Dpassmore
I'm running the DayStar 2 1/2" frt 1 1/2" rear kit. I need about another 1/2". I bought an off brand kit that claims it's a 3" frt 2 1/2" rear. My main question is, the frt DayStar spacer appears to measure 1 1/2" thick installed. The 3" kit I just got is steel and only measures 1 1/2". Seems Like it's not going to be anymore than I already have.
Also, I haven't heard of a 3"x2 1/2" kit. Seems like it will put rake back in it.
My fender to ground measurement is
LF 37. Rf 37 1/4
Lr 37 1/2. Rr 38
With dirt bike gear on the left rear and a full tank.
I know I need a better lift, but don't have several hundred to spend right now.
So will this give me the extra 1/2" in the frt I need?
The front spacer lifts (I think) are roughly 1.5", which result in approx 3" lift in the front. The rear spacer is 1:1. Why the extra 1/2" needed? I was running a 34" tire with CBI bumper 1" BL, 1.25" Spidertrax, and a body mount chop. All good. Are you trying to minimize trimming?
I'm running a stock bumper. My offset on my wheels is just enough to make it rub on the frt. already pushed the liner forward. May try and go a little further. Not sure why a 3" kit would measure the same as a 2 1/2" kit...
May try a 1/4" too.
Jhunt
