Front spacer install question
paraordnance
planning to install 3" leveling front spacer. The one goes on a top of strut assembly. Looked behind a wheel and see that it should be easy job, do I need a ball joint separator or I can do it without? I dont have to get strut completely out, just need a room to rotate it 180 degrees.
3" is way more than a level kit. The front will be visibly higher than the rear even with nothing in it. Think twice before you do this. The car will squat in the back with anykind of passengers/junk in the trunk.
I think it looks dumb when the front is higher than the back.
he's got rear air, which can be fooled into max ride height at all times fairly easily...which would level it out.
-to the OP, as far as I know, you only need to remove the sway bar links, and you will not need to remove the balljoints at all.
Looks like I wont be the only lifted 4th gen in edmonton ;) My lift comes in this week, and I have a new set of BFG AT KO's to go on also
yes, that rear air limits me from doing anything at the back without modifications. 3" on front should be just perfect. I can always raise back 2" extra inches on demand. I measured from center of wheel to fender and a difference is around 2 1/2" and my rear never sags. I dont affraid to be slightly higher at front. 265/70/17 Duratracs going right after. I will attempt install spacers next weekend
You can do this without removing the upper ball joints. Use the stock jack placed upsidedown to push the ball joint down. Be careful! Make sure that the jack doesnt slip.
It's best to unbolt the anti-sway bar links and remove the strut completely from the vehicle. I am not sure how you'd expect the place the spacer without unbolting and disassembling the strut.
Here is a link to a step-by-step with pictures of me installing coil spacers on my 98 4R:
http://www.toyota-4runner.org/showthread.php?t=55321&page=2
nice! I orderd my daystar kit from a local 4x4 shop and I've been waiting about a month for my parts to come in! I got a set of spidertrax spacers for badass stance also ;) my lift should be in this week, so I hope to have it all installed by the end of the month
you should check out www.ct4wd.com its calgary toyota club, but theres a few people from edmonton on there.
I just registered with ct4wd a month ago. When I get my lift and tires I'll become a full member and do some trail runs. I live in Red Deer, so I'm right between two major cities in AB ))
nobody posts on that site at the moment, so it kinda sucks.
Make a build thread on there when you get your lift on! I plan on posting up all my progress pics when I get my lift in.
