Front Strut/Spring (coil over :-D ) Replacement
JKD
190k miles and my front end is gaff / rear end is bouncing all over the place/bottoming out.
Decision/information paralysis....looking for a pre-built strut/spring (coil over I guess) for a reasonable price/quality.
I don't need lift or massive off-road capability, scared of the horror stories I've seen on cheap stuff (Monroe etc.) and just when I think I've found something.....it states "added 3inch lift to my ride..."...just don't need that on a daily driver..95% on road.
I really don't feel like buying/renting tools and building these myself, even though it appears painfully easy..if potentially a little dangerous!
Help! Please?
I settled on KYB Gas struts for the rear...may or may not replace the stock coils (truck is at 34" ground to fender - which I think is stock height for 2001)
As a didactic aside: The fronts are coilover shocks, not struts. Many people call them struts even though they aren't.
If you have the tools/ability to remove and install the front shocks, you can take them to a shop to have the springs, etc. moved to the new shocks for cheap.
KYB, Bilstien 4600's or OEM are all good daily driver options.
-Charlie
-Charlie
Thanks, yeah..I learned to call them coil overs from this forum....even though 90% of the world does not. I did put put it in braces.. ;-)
I have yet to find a pre-built option that isn't prohibitively expensive/overkill for my needs. Was hoping someone had :-/
I am in a similar situation as yourself. I purchased an 02 SR5 with 230k miles on it shortly after winter ended here in Denver this year.
I ended up buying stocks from Rockauto.com and the brand is Gabriel. I have heard negatives and positives in regards to Monroe but heard mostly good things about Gabriel and went with those.
I still have to install them as they are sitting in a closet on my balcony. I spent most of the day today replacing rotors and pads and also a seized up caliper. Fun times.
GABRIEL G57066 Ultra ReadyMount: Front Right
https://www.rockauto.com/en/moreinfo.php?pk=4257156&cc=1388707&jsn=386
GABRIEL G57065 Ultra ReadyMount: Front Left https://www.rockauto.com/en/moreinfo.php?pk=4257240&cc=1388707&jsn=387
I hope this helps a bit in your search. I am looking up the best way to install these myself. Also a good thing to know about these is that they are pre-assembled so essentially unbolt and bolt on but I am looking at more specifics seeing if anything else needs to be done while I am down there.
I have the Gas A Justs and like them. Big improvement over 20 yr old parts. If you arent concerned with lifting; I would remove the coil overs and have a shop swap the springs for you. Shouldnt cost much and I would imagine you could wait there for them to do it. May as well buy new mounts too.
seltzernator
