front suspension question part #'s
3bears
Senior Member
2000 4wd
so I am planning to do a near complete refresh of my front suspension, bushings ball joints etc, top and bottom
I'm not lifting, not going poly, just oem
I did oem lower ball joints and new springs (talls) and shocks 40 k ago so gonna leave them alone
but when I go to camelback Toyota, it lists all the bushings and balljoints as 2wd
also showing upper control arm bushing same front to back
referencing other sources they don't specify if 2wd or 4wd
does it make a difference
thanks
The bushings are the same, but if you click on Front Suspension and scroll down to view ALL 10 DIAGRAMS you will see double entries of some sections, those are the differences between 2WD and 4WD models
Sample, the spring/spindle page, here is the 2WD page
https://parts.camelbacktoyota.com/p...siteid=214329&vehicleid=84047&diagram=8414250
Here is the 4WD link
https://parts.camelbacktoyota.com/p...siteid=214329&vehicleid=84047&diagram=8414253
UCA bushings are the same for all 4 (left, right, inside, outside, 2WD, 4WD)
2000 4wd
thanks
I bought the following part numbers from toyota partsdeal for a 2000 toyota 4runner sr5 4x4. I verified the parts against my Vin number and they fit after a bit of heat and a press.
48061-35040, Front Passenger Side, Front Driver
48061-35050* front passenger side, front Driver
48632-35080. BUSH, UPPER ARM LH qty 2
48632-35080. BUSH, UPPER ARM, RH qty 2
Toyota Part No.: 43310-39016
JOINT ASSEMBLY,FRONT UPPER. I did not replace these but the part number was in my notes.
DionicioLives
