Front Sway Bar Size
Looking to put greasable sway bar bushings on the front to frame of my 5th generation. I can't seem to find the size anywhere though. I measured it as 30mm, is that correct?
Does yours have KDSS or not? I'm assuming not. I have KDSS so can't help you there, but I would imagine there's available part numbers somewhere (summit, jegs, daystar, energy suspension, etc) for 2010+ 4Runners without KDSS.
Not sure if I have ever seen the specs (have not looked hard) but if you have access to the sway bar why do you not trust your measurements? I always field verify drawings not drawing verify what I saw in the shop or field......now the sway bar may neck down at the bushings where you wouldn't have access to unless removed (not sure how far you went) either way if you have the truck and a set of calipers you should be good to go
044runner4
