FS - 1985 1st Gen $19K
v8turbo
Sold
Factory OEM AC, LED Internal lights, LED headlights, Rear Warn power plug for rear winch or jumper cables, Blue Sea power interrupt switch for rear power.
Full Drivetrain Replacement with all new parts. 22RE Performance motor – every option available, Marlin Crawler, ARB, WARN, OEM Toyota, TRD, RCV, Hella Horn, Trail Gear, AllPro, Optima, Blue Sea, Factor55, Wet Okole, Rigid Industries, Old Man Emu, ...etc. Only the best used.
Items Replaced/New -22RE Motor, NEW Cooling System(OEM Radiator and water pump), NEW Charging System(OEM Alternator), New Starter, OEM AC, Old Man Emu Suspension, Brakes(upgraded V6 calipers, rotors, dual diaphragm booster, Master Cylinder, High Steering, Exhaust/Muffler, Catalytic Converter, ARB Front Bumper, Trail Gear Rear Bumper, Warn 8000S Winch, Lights, RCV Axles, Bearings, Seals, Gaskets, Knuckles, Differentials, Ring & Pinion, New Custom CV Drive Shafts, HD Marlin Transmission, HD Marlin Transfer case with 4.71 Low, Wheels, Tires, Trail Gear Side Rails, Hella Horn, Gaskets, Hoses, Belts, OEM Bolts, Etc.... All new parts.
Professional installation by a master Toyota tech that does the motor installs for 22RE Performance in Chico California. I shipped the 4Runner to Chico for all mechanical work.
-22RE Performance - I asked Jim to build the motor to last a lifetime. I said - Don't even ask, just add every upgrade available. Everything new. The best valves, Pistons, Injectors, balanced, blueprinted...etc. The motor is so smooth and revs very nicely. Professionally broken in before I even shipped it back.
NEW PARTS:
-Marlin Crawler - HD 5 speed with Marlins short shifter kit.
-Marlin Crawler - HD Transfer Case. 4.71 low upgrade
-Marlin Crawler - V6 front calipers, Rotors
-Marlin Crawler - V6 1.5 Bore Master Brake Cylinder
-Marlin Crawler - High Steer
-Marlin Crawler - 4.88 Ring and Pinion/Full rebuild on axles
-Marlin Crawler – Welded Diff Covers Front and Rear
-OEM Toyota Dual Diaphragm Brake Booster
-OEM - Alternator
-Old Man Emu 2.5" Suspension kit
-Bilstein 5100 Shocks(extra pair in box)
-Wheelers Off Road Super Bump/Bump Stops on front
-Warn M8000S
-Factor 55 Prolink/Offset Fairlead
-ARB - Deluxe Winch Bumper
-Trail Gear Rear Bumper
-All Pro - Sliders
-Offgrid Engineering Custom Dual Battery System - In cab Switch
-Optima Yellow Top Batterie and Deka Intimidator
-Low Range Off Road battery- Box Powder Coated
-Pro Comp Wheels
-Goodyear MTR’s 33x12.50x15
-Blue Sea - Below Deck Panel in Rear for USB/Cig power
-Blue Sea - Fuse block for individual fused accessories, dedicated power interrupt, Rear Switch interrupt for Warn Plug
-Spider Trax - Toyota Wheel Spacers
-RCV - Front Axles
-Rigid Industries, 2 Aux - Dually Side Shooter's
-LED Headlights
---Much Much more of OEM parts, OEM bolts, OEM plastic pieces.....etc.
I am sure I missed a lot - but you get the idea.
[/IMG]
IMG_3830-640.mp4
Philthyphilthy
