FS: 1987 4Runner Turbo SR5 5 Speed - TX - $12,500
The Count
I'm going to sell my 1st gen and figured this was a good place to start. It's an '87 turbo SR5 that has a Marlin Crawler W56-B 5 speed swapped. The asking price may seem high, but this is an amazing example and I had someone offer me 10k without even driving it ( I wasn't interested in selling it at that point).
It has 111,557 miles on the vehicle. The motor has less than 10k on it. The transmission has less than 1k on it.
I purchased this from a person who had a collection of super clean, at least partially restored, older SUVs. He had a shop full of them, 4Runners, Wagoneers, Land Cruisers and so on. This one was a low miles, just over 100,000, example that he had semi restored. It had the motor and trans removed and both rebuilt. It was then painted, including undercairage and put back together. He drove it occasionally and it would up with around 110,000 miles on it when I bought it. I swapped the 5speed setup because the transfer case chain had slack in it and was rubbing inside the case, causing aluminum shavings in the fluid ( in the auto trans the t-case shares fluid with the transmission). Parts aren't really available for the auto that came with the turbo motor, so a 5 speed swap was my choice.
This 4Runner runs and drives like new, and I've put ALOT of time and money into it. I'll try and make up a list of things I've done or installed in another post. For now I'll put up pics and a link to the photobucket album here....Turbo Truck by Blah Blah | Photobucket
I'm located in Fredericksburg and am available anytime to meet with you. You can reach me the quickest by texting me at 830 998 6660.
Parts involved with trans swap:
Marlin Crawler W56-B 5 speed transmission
Marlin Crawler short throw shifter kit
Marlin Crawler shifter knobs
Transfer case with unknown mileage from a forum member here
Aisin clutch master
braided stainless cluch master to slave hose
Aisin slave cylinder
Aisin clutch kit
used Toyota flywheel resurfaced by me at work
used Toyota pedal assembly stripped and painted
new clutch and brake pedal rubbers
Shifter boot from leather maker from Texas who sells on eBay
Trans is filled with Redline MT 90 as is the transfer case.
Parts added:
ARB front bumper. Led lights are mounted in pre existing holes, not drilled.
Trail Gear rear bumper
Warn Locking front hubs
Headlight conversion to 9003 bulbs with optional halo Leds
JBL 6x9 rear speakers
Rockford Fosgate front speakers
BOSS double din radio unit
XM radio receiver mounted in ash tray, is removable if you like.
Falken Wildpeak A/T 30in tires
Weather tech trim to fit floormats
New side pillar 4Runner emblems from eBay seller ($100)
Rear tail light lenses (the orange had faded over the years)
Mechanical maintenance I've done in the past 1k-ish miles: (forgive the lack of structure to these lists, I'm going off the top of my head or through receipts to make them)
Gates belts
Gates hose
Aluminum raditator
Ngk wireset
Ngk plugs
Fram fuel filter
K&N pod filter setup (have original)
Front and rear diffs got Royal Purple synthetic gear lube
PRICE DROP
Only have had a couple of people serious and all seem to cap off at the $10,000 mark. So I'll lower the price to that... $10,000. Overall I'm likely loosing money at either price (if I added up every penny spent), so I'll drop the price to try and get this sold.
youngrk
