FS: 1999 3rd GEN SR5 4x4 (E-Locker) Savannah, Ga
Buck208
****SOLD*****I am selling my 1999 3RD GEN see below for details, hopefully I've included enough information but don't hesitate to ask for something that I may have not mentioned. Thanks for looking. I have this listed on CL as well for $300.00 more. Price: $8,200.00. Craigslist ad: 1999 Toyota 4Runner SR5 4x4 (E-Locker).
1999 4runner Sr5 4x4 (Savannah, Ga): Current miles 175,900, Desert Dune Metallic. Factory E-locker. Oil changed every 5k miles or 6 months with Toyota oil filter and Mobil 1 5w30 Synthetic. Tires rotated at oil change interval. Everything works: windows, locks, cruise, 4Wheel drive, locker etc. Some cosmetic blemishes with paint (it is a 17 year old 4Runner).
Maintenance: (Have receipts for all parts/ timing belt/water pump service)
1. 141,xxx- 5/18/13- Spark plugs/wires, pcv valve, valve cover gaskets, B&M trans cooler
2. 143,xxx- 8/10/13- Replace front lower ball joints, inner and outer tie rod ends
3. 152,101- 3/21/14- TRD throttle body gasket, clean throttle body and mass air flow sensor
4. 153,396- 5/3/14- Replaced auto shifter bushings, replaced fuel filter/fuel line from filter to engine bay, extended rear differential breather (located by gas cap)
5. 153, 981- 5/17/14- Lift kit installed with alignment
6. 154,902- 7/5/14- Replaced all drive belts and a/c idler pulley, blue wire mod
7. 156, xxx- 10/12/14- Installed SR5 wide textured flares
8. 158,965- 2/20/15- Coolant flush- used BG coolant system cleaner and flush machine, replenished with OE red Toyota coolant and distiller water 50/50 mix
9. 159,913- 5/30/15- Replaced left and right front cv axles (NAPA New), rear Toyota brake shoes, NAPA rear brake drums and wheel cylinders, parking brake bell crank kit, Installed SS extended rear brake line, flush brake fluid with Toyota brake fluid
10. 161,294- 6/13/15- Replaces left and right inner and outer tie rod ends with Toyota parts, installed LR UCA’s, alignment, installed FJC steel wheels
11. 162,xxx- 8/2/15- Tundra Brake Upgrade (NAPA calipers, OE rotors, pads and shims)
12. 164,496- 11/25/15- Replaced timing belt, water pump, front and rear sway bar links, installed Tan Weather Tec floor liners front and rear
13. 165, xxx- 12/15- Installed new bump stops, Goodyear Duratrac tires and Tundra wheels
14. 171,191- 3/17/16- New front bumper (stock), front lamp, grill
15. 174,854- 6/8/16- Coolant flush
Modifications/ Upgrades:
Body:
1. SR5 wide textured flares
2. TRD Off Road Decals
Wheels/ Tires:
1. Goodyear Duratrac 285/70r17 tires
2. Toyota Tundra wheels
Front Suspension/ Steering:
1. Tundra Bilstein 5100’s 2nd perch with Tundra TRD Springs
2. SPC/ LR UCA’s
3. Toytec Differential drop
4. Energy Suspension Urethane Steering Rack Bushings from Wheeler’s Offroad
5. Extended swaybar links
Rear Suspension/ Steering:
1. LC 8 wraps with LC Tokico black shocks
2. Extended swaybar links
4. Toytec panhard drop bracket welded to frame
5. Custom built .250wall DOM rear LCA’s, bushings are OE Toyota
6. Custom built .250wall DOM adjustable rear UCA’s, frame mount bushings are adjustable Johnny Joints, axle mount bushings are OE Toyota
7. Upgraded Bump Stops
Drivetrain:
1. B&M 70268 Trans Cooler
Electronics:
1. Scanguage II
2. Cobra 19DXIV CB Radio/ Firestick Antenna
3. Kenwood DDX7019 In-dash DVD
Brakes:
1. Wheelers Offroad SS extended rear brake line
2. Tundra front calipers, rotors, pads, shims
Misc:
1. 1ST GEN 4Runner Roll Bar
  • Pic 4.jpe
    Pic 4.jpe
  • Pic 5.jpe
    Pic 5.jpe
  • Pic 1.jpe
    Pic 1.jpe
  • Pic 3.jpe
    Pic 3.jpe
  • Pic 31.jpe
    Pic 31.jpe
utkrstam
