FS: 1999 4Runner SR5 4x4 5-Speed eLocker 118k mi Detroit, MI
Skinfaxi
$12,250
1999 Toyota 4Runner SR5 4x4
Desert Dune Metallic
Tan cloth interior
5VZ-FE 3.4L V6
5-speed manual transmission
Factory rear locking differential
Shrockworks front plate bumper
PIAA fog lights
Savage Offroad hybrid rear bumper w/ swingout tire carrier
5x 5th Gen TRD Pro wheels w/ BFG KO2 275/70R17 (1500 miles)
ICON Vehicle Dynamics Stage II 2.5" Front adjustable coilovers
ICON tubular upper control arms
ICON 2" rear shocks
OME 890 rear springs
Tundra 231mm big brake upgrade
Pioneer touch screen w/ bluetooth
Pioneer door components & tweeters
Uniden CB radio w/ 5' Firestick
Weathertech floor mats front, rear, & cargo
Two sets of mint OEM carpet mats
Two keys, two fobs
Original cargo cover
Factory bumpers & running boards included in sale.
118k miles
I purchased it from the original owner in Arizona in 2013. It remains rust-free.
Cons:
-Hood/roof had faded clear coat from Arizona. They've been resprayed, and the color blend to the sides isn't perfect.
-The rear hatch has been replaced following a dent from the tire carrier being mis-aligned (badged as a Limited)
-The front bumper and fenders have a few dents.
Everything works: A/C, heat, rear heat, rear defrost, heated mirrors, 4x4, eLocker, power antenna, rear hatch power window, etc.
Zero malfunction lights or mechanical issues of any kind.
Maintenance:
Date Mileage Description
08-21-13 87175 Oil Change
08-21-13 87175 Engine Air Filter
08-21-13 87175 Timing Belt
08-21-13 87175 Accessory & AC Belts
08-21-13 87175 Clutch & Throwout Bearing
08-21-13 87175 Re-surface Flywheel
11-08-13 89800 Rear Hatch Lift Struts
04-05-14 90959 Oil change
09-18-14 94700 Trans & transfer case fluid change
11-19-14 95555 Oil Change
12-28-14 96008 Front & Rear Diff Fluid Change
01-05-15 96012 Tundra Brake Upgrade
01-05-15 96012 Braided SS Brake lines
11-15-15 99789 Oil & Filter Change
12-30-15 100538 Lower Ball Joints Replaced
12-30-15 100538 Front Sway Bar End Links
12-30-15 100538 Clutch Pedal Bracket Replacement
12-30-15 100538 Headlight Bulbs
12-30-15 100538 Rebuilt/Re-sealed headlights
07-22-16 106000 Oil Change
09-03-16 106600 F/R Diff/Trans/XferFluid Change
11-20-17 112500 Steering Rack Bushings
11-20-17 112500 Driveshaft rear u-joint rebuild
11-20-17 112500 Oil & Filter change
12-15-18 116500 Accessory & AC Belts
12-15-18 116500 Lower Control Arm Bushings
12-15-18 116500 Steering Rack, inner & outer tie rods
06-01-19 118000 Battery
Link to google drive gallery:
Pictures - Google Drive
I'm thrilled to be the next owner!
Sent from my SM-G965U1 using Tapatalk
