FS 2d Gen (95) 4Runner - $2900 - NY/CT/W.MA
ts01-4Runner
FS 1995 / 2d Gen 4Runner SR5 - $2900 - NY/CT/W.MA
1995 Toyota 4Runner 4x4, 3.0 V6, auto, 129K on the body, engine with +/- 90K.
More pics and info here: 1995 Toyota 4Runner 129K
2d owner, light use on vehicle for the last two years. I purchased it from a mechanic who swapped in an engine with roughly 87K following head gasket failure on original engine. My mechanic also installed new brakes, brake lines, battery, rear window motor, hoses & belts. Since then I put in a new starter, alternator and trickle charger, speakers, and spare tire rim. Fluids changed regularly.
The good - starts and runs reliably; AWD works well; heat and A/C work well; exhaust is in good condition; all electrical OK (except radio); body and frame in very good condition (minimal rust); tires in good condition; clean title.
The bad - minor rust repaired over the right wheel wells and rust on one corner of the rear bumper (see pic above, and close-up in Craigslist ad); torn drivers seat and some cracked plastic on dash and interior trim. Radio is not working. Check engine light intermittently appears but it runs reliably and passed recent inspection in MA and should pass in NY as well, because OBDII inspection applies only to 1996 and newer vehicles. (See https://dmv.ny.gov/brochure/new-york-state-vehicle-safetyemissions-inspection-program; https://dmv.ny.gov/brochure/what-do-you-mean-my-cars-not-ready.)
Can be seen in Westchester County NY, Stamford CT, or with some planning, Great Barrington, Massachusetts.
Asking $2,900 o/b/o.
