FS: 3rd Gen 2002 Sport Edition Custom Build - $18,000 - Sacramento Foothills, CA
Foothillsflyer
*****Update 31Mar2014*****
SOLD - 16K - Craigslist
Thanks Everyone For all the Build Compliments and Nice PM's!
2002 4Runner Sport Edition
Excellent Condition - New Custom Build was Just Finished
$16,900.00
Located in Foothills above Sacramento CA
Took a bone-stock 2002 4Runner Sport Edition and built to below specs. Currently stands w/ 163K Miles. I am not original owner but this rig had a clean Car Fax when I bought it. History shows Arizona and California owner history and there is no rust.
This rig was done professionally and done RIGHT by Concept Motorsports, Grass Valley.
Sound System and Alarm by Jim Inman and his Team @ Electronic Solutions, Grass Valley.
Everything on the truck is in good working order. The timing and water pump are documented at 123,905. The only things I can find needing repair would be the valve cover gaskets. We just noticed a little weeping is starting around the valve covers. It’s very minor, but something to address at some point. I haven’t gotten around to changing the plugs and wires so would probably do those at time of valve covers. The other item worth mentioning is the rear cargo roll-up cover. The truck didn’t come with one so I sourced a used one from eBay. It’s a slightly different shade of tan that the remaining interior. Most people don’t notice, but it’s worth calling out as the dealer quoted me $800 for a matching NEW one. The guy that sent me the roll cover threw it in a box with no packing material (not sure what he was thinking). As you can imagine it got rattled around in the box during shipping and managed to crack a few small pieces out of the end cap hangers. It still works OK, but since the plastic was damaged it causes the roller to slightly twist in the side brackets as you pull it open and into the extended position. The clips holding it on the seat head rest tubes seem to help stabilize it well. The cover works great but it’s not perfect or like new. And finally, the front ashtray was missing when I bought it. I don’t smoke so it never bothered me it wasn’t there. In summary, I take extremely good care of all my cars which is a bit of work considering I have a few to look after right now. Obviously, I can only attest to the care while this rig was under my watch, but we spent allot of time and energy (and money) to make this into a fantastic 3rd Gen.
Please PM me any questions.
Thanks for looking and Hope you Enjoy.
Here is the breakdown (minus a few details I may have overlooked or lost track of):
Engine & Drive Train :
Engine and Gears are Stock Set Up
Stock Center Lock Diff
4WD Hi Lo stock
Add On K&N Filter Concept Mtr
Add On Magnaflow Exhaust Concept Mtr
Add On External Tran Cooler Concept Mtr
Add On Large Radiator Reservoir (relocated due to dual battery set up-see pics) Concept Mtr
Lift & Suspension : (ToyTEC)
OME 881 Front
OME 90004 Front Shocks
OME Trim Packer and Top Place
Main Diff Spacers (diff Drop)
OME 890 Rear Coils
OME 60028 Rear Shocks
OME 661 Shock Stone Guards
Tires / Wheels :
FN Wheels Konig Six Shooter (Graphite Gun Metal 17X8)
Black SD Lug Nuts
Nitto Terra Grapplers AT : M+S P285/70R-17
Body & Armor :
Side Sliders Custom Fab by Concept Motor Sports
Front Bumper by Outdoor Logic, Modified by Concept Motorsport for better fitment
Bumper Color Painted to Match Concept Mtr
Repainted Hood Scoop due to oxidization Concept Mtr
Front Skid Plate Custom Fab by Concept Motor Sports
Rack :
Custom Built by Concept Motor Sports
Powder Coated Black Concept Mtr
Expanded Metal Inserts Concept Mtr
All Wires Internally routed (single plug for disconnect) Concept Mtr
Rack mounts into factory rails (roof has not been drilled or cut) Concept Mtr
Electronics :
Added 2nd Battery Concept Mtr
Custom Battery Tray by Concept Motorsports Concept Mtr
Dual Battery Solenoid and Electronic Controller by National Luna
New Drivers Door Lock Actuator
Stereo & Alarm : Electronic Solutions of Grass Valley
Pioneer Head Unit : DEH-X8500BH Bluetooth HD Radio
Rockford Fosgate Amp(s)
4 Channel Main (P600X4)
1 Channel Sub (P500X1BD)
Rockford Fosgate Remote Sub Control :
Speakers
Front Speakers : Rockford Fosgate T16-ST1 Power 6” Component
Rear Speakers : Rockford Fosgate T16 Power 6” 2 Way Coaxial
Sub Woofer : Rockford Fosgate P3D4-10 Dual Voice Coil 10”
Sub Box :
Sub Grille : Rockford Fosgate
Zero Gauge Wire from Battery to Fuse Block in Amp Location
Sound Matting/Dampening Material in Doors
Alarm : Viper w/ Pager Remote Model 3305V
Prof Install
Exterior Lighting :
Headlights : HID HI/LO Conversion (Done through Concept MotorSports)
Brake Lights : LED Conversion (V3 Triton Red High Power-VLEDS.com)
3rd Brake Light : LED Conversion (VLEDS 921_14_HP_R1 Red 5W)
License Plate Lights : LED Conversion (Putco 287431W)
Reverse Lights : LED Conversion (VLED 921_19_HP_W_5K White 19LED 8W High Power)
Turn Signals Rear : LED Conversion (VLED 7443_21_Amber)
Turn Signal Front : LED Conversion (3 AMBER LED w/ Clear Lens)
Turn Signal Load Equalizer (VLEDS V3_CLS_20)
Parking Lights : LED Conversion (VLEDS 194_10_CP_A Amber 10 LED)
Rock Lights : 8 LED Vision-X Multi-Color/Multi-Effect with Remote Control (Custom Frame Mount Brackets for LED assemblies, Concept MotorSports)
Behind Grill : 2 qty Zeus 6” Spot Beam (Custom Mount Bracket Concept MotorSports)
Bumper Lights : HID Pencil Beam (Concept MotorSports)
Rack Lights: (Purchased Through Concept MotorSports)
Front Light = Zeus 30” Flood Beam Concept Mtr
Side Lights = Zeus 6” Flood Beam Concept Mtr
Rear Light = Zeus 6” Spot Beam Concept Mtr
Interior Lighting :
Dome Light : LED Conversion (VLED DIY_48_SMT_WW Warm White 48 LED Board)
Miscellaneous:
Wet Okole Seat Covers
Wheelskins Leather Steering Wheel Cover
Hella Dual Red Horns
Window Vent Visors
Front Weather Tech Mats
Rear Cargo Weather Tech Floor Mat
$350 Professional detail... Clay Bar whole car, fresh wax, steam clean interior.
link to photobucket album
http://s1340.photobucket.com/user/Foothillsflyer/library/4Runner?sort=6&page=1
GLWS, looks very refined. Hope you get your asking price, cause I think it will bode well for me when I sell mine.:rockon:
Out of curiosity.. ad says "trail grapplers" however, those are clearly "terra grapplers" - typo or different tires on it now?
lindwlson982
