FS: 3RD GEN $4500-1998 Toyota 4Runner Limited 4x4 auto Dallas, TX
mikesayboom
Hey everyone, I purchased this 4runner from this site now four years ago and it has been the best vehicle I have ever owned. Its taken me from Dallas to Colorado a dozen times for snowboarding, camping, and Hunting trips back home in the Texas panhandle. I never planned on selling this and wanted to keep it until my daughter could drive it but that is still 6/7 years away and since Ive received my company truck last year shes sat in my driveway ever since =[
So my loss can be your gain. Below is all the work the previous owner did and all the work ive done to the car since my ownership. As you can see below i've done quite a bit of maintenance because i planned on keeping this car until forever and then when forever came I wanted to replace the engine and keep going. The LED light bar broke But I have two RC lights and drilled holes on the bumper for them and just need to be wired in to the switch thats already installed. I also did a HID retrofit myself that is plenty bright. If i can find the video ill upload it to show the brightness of it. If you have any questions please email me at [email protected] as I will get that faster then checking this site for updates.
1998 4RUNNER LIMITED
VIN : JT3HN87R2W9013929
PREVIOUS OWNER - Purchased 170,000 miles 7/11
Front Lower Ball Joint - 171,000 Miles
Outer Tie Rod Ends - 171,000 Miles
OME 906 Rear springs - 171,000 Miles
Sway -A- Way Front coilovers - 171,000 Miles
Oil Change Mobil 1 5w30 - 171,500
Coilover Rebuild - 175,000 Miles
Trans Fluid Change - 176,000 Miles
Oil change Mobil 1 5w30 - 177,000 Miles
T-Case Fluid change royal Purple - 177,000 Miles
Oil Change Mobile 1 5w30 - 182,055 Miles
Oil Change Mobile 1 5w30 - 186,973 Miles
Oil Change Mobile 1 5w30 - 192,900 Miles
Oil Change Mobile 1 5w30 - 197,544 Miles
Trans Fluid Change - 197,544 Miles
Front and rear diff change 197,544 Miles
Driver Rear Axle Seal/Wheel Bearing - 206,100 Miles
Spark Plugs OEM - 206,100 Miles
Spark Plug Wires OEM - 206,100 Miles
Oil Change Mobile 1 5w30 - 206,100 Miles
Oil Change Mobile 1 5w30 - 211,700 Miles
Starter - 215,500 Miles
Front Brembo Rotors, 215,500 Miles
Wagner Thermo quiet Pads - 215,500 Miles
Oil Change Mobile 1 5w30 - 217, 267 Miles
Purchased by Me at 217,500 Miles 3/24/16
Oil Change Mobile 1 5w30 - 221,628 Miles
OEM Valve Cover Gaskets - 222,225 Miles
OEM Spark Plugs - 222,225 Miles
OEM Spark Plug Guides - 222,225 Miles
OEM PCV Valve and Grommet - 222,225 Miles
Cleaned Throttle Body - 222,225 Miles
Oil Change Mobile 1 5w30 - 226,906 Miles
Transmission Flush and Filter Mobil 1 ATF - 227,000 Miles
Diehard Gold Battery - 228,818 Miles
Oil Change Mobile 1 5w30 - 231,836 Miles
Denso Radiator - 232,436 Miles
Denso Hoses - 232,436 Miles
OEM Radiator Cap - 232,436 Miles
Oil Change Mobile 1 5w30 - 235,071 Miles
Oil Change Mobile 1 5w30 - 239,308 Miles
Oil Change Mobile 1 5w30 - 244,707 Miles
Oil Change Mobile 1 5w30 - 249,824 Miles
OEM UBJ - 256,878 Miles
OEM LBJ - 256,878 Miles
Whiteline LCA Bushings - 256,878 Miles
SPC Cam Bolts - 256,878 Miles
Energy Suspension Steering Rack Bushings - 256,878 Miles
Napa Lifetime Warranty CV Axles Driver - 256,878 Miles
Napa Lifetime Warranty CV Axles Passenger - 256,878 Miles
Front Diff Fluid - Mobil 75w90 - 256,878 Miles
Transfer Case Fluid - Mobil 75w90 - 256,878 Miles
Rear Diff Fluid - Mobil 75w90 - 256,878 Miles
OEM Valve Cover Gaskets - 256,878 Miles
OEM Half Moons - 256,878 Miles
OEM Cam Plugs - 256,878 Miles
Five 0 Motorsports Fuel Injectors - 256,878 Miles
OEM Spark Plugs - 256,878 Miles
OEM Spark Plug Wires - 256,878 Miles
Inner Tie Rod and Boots - 256,878 Miles
Welded Slip Joint in Steering Column - 256,878 Miles
Firestone Alignment - 256,878 Miles
Oil change Mobil 1 5w30 - 260,464
Front wheel bearings, inner and outer seals - 260,464
Oil change Mobil 1 5w30 - 264,559
Brake booster changed - 267,446
VQO8YChFoeFL1GEYgRFGKP-QDjSwnP9dFHN4nNETTXzuycsyIpInpC7a237awbv8I1bJ_qV9Zs-c-wMvs1C0rWOFwa_2sR2FlZaCxKXRhN-kmfZNgDIBCEPKRRMIDaeLAE1PVHGEGTCnCJfyUIMs4pu2iCPaIvel36GH0_eT6FoxbLD6ZvtDxlOxyE6aRlv26XQlZrkTXQuytHEuIjhlt3qGKTen7lcIgDsSB6EfmEfJI359wBHHPTHk_KmeZnPnJdJBvhbaBE1zsoyNKVP1phyeDb20cC6PKQzQFgGD67-y1qucDfvbU5RnRjzNZd_JfySD7f8t2kU2hxF5nPoBx5vQnkH2TRMHT9kbpnMULF2Q_l5rxAtRq_XEkJN3WyAO60Zpjfd2lmUvYb8JHqgWYU3M8ZOMPvkAkA_GA-BaKHrCeTpdG2LEbXZMVO0HX3ZYodfa619949Q577hOm84amlZIUdRRXdwyImzdSm3Nu996-yhBxSlz4gk2foFzoTTg5iCcMUgUgJ13rr8TSetFKZT9IJDKhetCdG9Gxyzo5Udc1r40c-WKcZgz89ElVUNA_Qw9McKb56-Ysp5M5SavIM9LD8EYpZ-kKyHuKonT_tC625UFQWYcQq2y1k8XSxGNMYkJvsmRgmEwWd9aaMt-PeFC2wbkiO55ohdrdnZshcuRfQoBbQTZvxEf_cGeoQ=w2053-h1368-no
Tm4foqNRGRHjTQxPvlJ5W6PGUeLUC4Wg6vH4jejmSZNWFHsSyEn2gL4h3hm78HvjPazGQdIE3FCnv942WQohc5feE5QY_Qgt4xx1BS8s8sI9QPOBVuJ2uL-WcJ0SR2nduiiwAwZ9JmmYJ_d92_1mjKRqnJGu4RAPOnDKmfkkLiVfullTgMjCdMG9mMIxGHYgEHiJLqnutLCzXCnOWGo-oO5SVqWgl1yhboUyRNHGSxBq1YpsBHw-13UqvWVMF2rFgA8vcvpg4bLnsCy1oTdWmjcaouyObG5MAXgsl0QZ4IqkIB7Xeon27RoP1RY6Ba64SjTPrWZKHM00JI5pArRu7urfMjvlu1Vg5WYdgwky7Cl9DOieorAWHGicfVy-yPUw-Vf7n_p8gUXPhPvG1Y35UV427G5iBulsO_8ASVsA9vBiPctiWlYx0XvVrKmCsgmBNAPzKbMqLVTkFoiCCdinv-xw489ctRIvM09-srUXv0Us4mhD1gF4C0ZDzGU2X4rmM0486srV-NIS2bGulJ3wonMX6c52lv7zPKkW6k172fOthtVCmjlvriqv1zfpTEt_lpG2sjNvOqyEPSZmCeOTrEoq3pHyOxp7WAxom5eQNSO5FbE-zXcGe-tmcSmEowCTEYO4RDBFMigFd8DEPQmQKZI_GjkR0uYfvY8FQiXkBUnsexS8iW3jGioY6qtSdaMipF6R3SEdhRiPV1FHnUWmMvK_bYr6I4AhPe0_VObTeHpURUr_trEGMdk=w1824-h1368-no
qm_LtdYkJpswL6C3HkuHnbBiWtT2TdhyHA4oxcIL67hK3oPJy9O1mIb0myhp6ZNOXn3Wdm5iabPbsvpJQPIEdSRq6EzSKX0x7BNnKqrHvXMtJuTYqXT-grRgtx46JFm2ahQ5e7Kzy2SYJ8mGaX4YCkK06Pa9CcyNB2WLGSUXz18nZD57Sdo4oJSdMu7NBNJQqY98ufu1C6IpJfEk-T3INS-1qiOxGjfLFT5HSXUZs9BTGr_lAbOF0uGf-F0iOgkXGuuxb9RhXhh19nhghKzqMtRUcfH4zc-8Uh3gNMzAgurltMt0YcZfcBvWiEmKqZcr1exonVD7orjKNwEtSCkeih5x1K0n5fA9F7Wd9Zv0EkWfneDE2vM_gCJcIxZgu_wQQGck_xyR88pfWRXZ4FRIRZN15BeCodDrysLMhOg26W5D7m_foEW7l3gV-vKdOfdOpBKgc_3gPIayhrMhZSFwUJUFkuGa08qAywvvGaz6fUL8OGqTSiZgTB_C831ajpBOvUaJSrMc2jpz0MXpI6tSfCk12D-5aiPFTLidmUoPP8NibBlDy1XfWOrgL_ahDWVk0RfdYiqrQOcJ99VtNZ754buwr1arFVpUPl2SDHybaibq4vqLX7FPGsjHuuIghp7TAyu2jPydbfuFO7lApBJ1qqBqS-GOg0ym9Lm4qvujL1gWnlwhRCTSsZqN78fddQ=w1824-h1368-no
IugXyrJrzcgGWLe1kJ9Og412n-mYzHxqUQpjh_Y8fAInN_eaFvpAzEykkEueg0_an9C0ATualcY60yGgKg91TBL1DVDpC0-galunIvtZFWh6JHxq8jsK8t7GVnT_e3HttlzaGvaOl5CNXwgl99yNud4ZnOcP9U_8VtiNwMMAXM-mIscT87lQnMuPT4OaS-yLXrH_X-NH4LQCkKPCzwb6tX0WmwAgw81eHE1QAII_NsFJAZ30LPulA6lbpoQXDyZmM_Z-jYTVOG3p-3eIvtHxDh5D0pOyVgz4z0qxQEp-Blf41W8pGRssyA5KcQeYZEy-LFuwx6bda-7o8BCxFa5NFcJx3R9UfGrgEzGJ52BdT4UEhjH2zLL8IohlobBVFOFH4_u__7f59By-OKmA1WrPQ1dZD0QqWJr7047kS_I-z7FXw6stERIQ9seumtK0lshzJtNy3iloVj66cvpm9gN-Kq1yaiJdh4A3p98v6lK-ir-NTAntZKMS3mykFjX85ZMjkr_8rJUCwLyYiBaOG13pKhtmVfx73i8GGzmdhkoiPq2wpk4d_DgcLys-ATS-1bu3TbQqO0p0Il4x2vTJrE8qjDuOXHiB3nkRmJ5p-rYcb-5UZVECquY40GW3DnDXSUegD4GAY8RaRKeL7KJ6xg6q89aMUCwNJAtRpegC3G9FcodnCkevAwNLFGRhqQoldQ=w1824-h1368-no
Retrofit Video highs and lows
