FS 3rd Gen 4runner $8000
jgilbreath
Detailed pictures can be seen in my album.
It's time for my family to move on to a larger vehicle. My wife and I bought a travel trailer recently and need something with more power for towing duties. As much as I hate it, it makes more sense for us to sell my 4runner than her 2011 Honda Pilot. I bought the 4runner almost five years ago from Round Rock Hyundai. It has been completely reliable since then, which is why we bought a 4runner to begin with. While I have owned it I have kept it extremely clean and well maintained. My original plan was to drive it until my daughter (now 11) started driving, then she would get the 4runner. If I could afford to keep a third vehicle I would not be selling, but that's life I guess. Below are a few specs with some notes. If you have any questions or would like any additional information please let me know. Thanks.
Year: 2000
Mileage: 220,300
Trim: SR5 (with limited flares)
Trans: Automatic
Engine: 3.4L V6
Drive: Four wheel drive with e-locker (4.30 gears)
Color: Desert dune metallic
Interior: cloth, sunroof
Wheels: Level 8 MK6 in gunmetal
Tires: Cooper Discover AT3 265/75/16 C (tires have 23,000 miles on them, 10/32 of tread remaining, rotated every 5k miles)
Front bumper: 4x innovations (with vision x halo fog lights wired to OTRATTW switches)
Rear bumper: Shrockworks
Skid plate: All-pro offroad front skid plate
Current fluids:
Oil - Mobil 1 5W-30 synthetic (high mileage)
Coolant - OEM Toyota red coolant
Transmission - OEM Toyota transmission fluid
Transfer case - Red line synthetic gear oil
Front differential - Red line synthetic gear oil
Rear differential - Red line synthetic gear oil
Brake fluid - Synthetic DOT 3
My maintenance records (sorry for the formatting, it doesn't seem to copy well from my excel spreadsheet).
Date Miles Service
3/1/2014 185,895 Purchased
3/2/2014 185,900 Weathertech floor liners
4/1/2014 186,000 4X innovations front bumper
186,000 4" round fog lights
186,000 Tridon EP-35 relay
10/20/2014 190,085 Oil change, rotate tires
10/20/2014 190,085 New rear lift gate struts
3/31/2015 193,000 Power steering flush
3/31/2015 193,000 Redline SL-1 fuel cleaner
4/1/2015 194,250 Redline 75W-90 gear oil - 6 quarts
6/23/2015 194,250 Front differential drain plug gasket
Front differential fill plug gasket
Rear differential drain plug gasket
Rear differential fill plug gasket
Transfer case drain plug gasket
Transfer case fill plug gasket
Visor holder
106E Clip (door)
106G Clip (flair)
106D Grommet (flair)
6/29/2015 194,895 Air filter
Fuel filter
Clean Mass air flow sensor
Tighten throttle cable
7/21/2015 195,100 Shrockworks rear bumper
Rear differential union
Rear differential breather
8/1/2015 197,000 Brake booster replaced
10/30/2015 197,100 265/75/16 Cooper AT3
Level 8 MK6 wheels
4/13/2016 200,000 Rotate tires
4/20/2016 200,100 Oil change
6/1/2016 201,000 Spark plugs
Spark plug wires
6/5/2016 201,100 Battery
7/14/2016 206,740 Grease drive shaft
Vaccuum hoses
Oil change
Rotate tires
Starter contacts & plunger
Front sway bar bushings
Front end link bushings
1/7/2017 208,000 OTRATTW switches fog lights
2/28/2017 210,500 Oil change
3/4/2017 210,550 Rotate tires
3/9/2017 210,580 Mass air flow sensor
6/25/2017 212,000 Front brake pads
Rotors
Front brake lines
Brake fluid flush
7/24/2017 212,500 Lower ball joints
Valve cover gaskets
Spark plug tube gaskets
Valve cover bolt washers
PCV grommet
Camshaft housing plug
lower hose - radiator
upper hose - radiator
radiator cap
Radiator
Timing belt
Idler roller
Tensioner roller
front cranskshaft seal
front camshaft seals
water pump
water pump gasket
hydraulic tensioner
thermostat
thermostat gasket
AC belt
Alternator belt
power steering belt
Clean throttle body
Clean IAC valve
IAC gasket
Throttle body "O" gasket
PCV valve
Coolant flush
Transmission drain/fill
Labor
3/7/18 215000 Oil change
Rotate tires
11/30/18 220,000 Oil change/grease driveshaft
Rotate tires
Noice.
I like how well you kept your records. Any chance we could get some more pictures? I'm interested but I'm all the way over here in Albuquerque.
On the left below my member name there is a link to "Member's picture albums". The are a bunch of detailed pictures there. If you are looking for something specific, seems me a message with your cell and i can text you.
