FS: 3rd Gen 4Runner Limited, Vancouver, WA, $13k OBO
Fiffa
Member
SOLD SOLD SOLD
The time has come to let this truck be enjoyed by someone else. I put a lot of effort into making sure she could take me wherever I wanted to go, and to do it in comfort. She's a workhorse, not a show pony, so her condition is good, but not pristine cosmetically.
I bought this with 255k on the odometer and the second owner before me did a bunch of work before I took over. Here's the specs and everything between him and I that has been done from 235k to now (272k):
5VZ-FE w/E-locker
MAINTENANCE
- Full timing belt kit and water pump from AISIN (OEM)
- New radiator
- Geniune Toyota lower ball joints
- Inner and outer tie rod ends (Napa)
- NGK plugs and wires (OEM)
- New ignition coils
- New crossover exhaust gaskets (OEM toyota)
- Valve cover gaskets and intake gaskets (DNJ)
- Denso o2 sensors (OEM)
- New Toyota throttle position sensor
- Cleaned MAS
- Seafoamed engine
- Wix Fuel filter
- Power steering fluid flush
- Steering rack bushings
- Steering rack guide updated with new Toyota parts
- Changed all gear box fluids to synthetic
- Rebuilt rear brakes, adjusted e brake (Powerstop components)
- Replaced cv axles
- New battery (Interstate 24F AGM)
- Rebuilt starter with new brushes/contacts
UPGRADES
Engine & Drivetrain:
- Nitro 4.88's w/ ECGS needle bearing bushing upgrade
- Airbox deckplate mod and ISR Mod with K&N filter
- 4 hole Denso fuel injectors (OEM upgrade)
- DC Power 180A alternator upgrade
- Hayden 678 trans cooler w/ Magnefine magnetic filter
- Custom engine bay wiring w/ big 3 kit, circuit breakers for added protection, and additional fuse panel for accessories
- Magnaflow Overland Series catback exhaust
Suspension & Brakes:
- Bilstein 6112 3rd Gen 4Runner specific
- Sonoran Steel Works 1/4" strut spacers
- Bilstein 5160 4th Gen 4Runner
- Dobinsons C59-210v springs (LC front coils that work on the rear)
- Durobumps 2.5"+ option, F/R
- Eimkeith PCK
- Mstudt rear end links
- Front sway bar delete
- Sonoran Steel tapered diff drop kit
- JBA UCA's
- 13WL Tundra brake upgrade with Powerstop drilled/slotted rotors & HD braided brake lines
- E-brake bracket made for lift
- Extended rear brake line with stainless braided line
- Whiteline LCA bushings
- Rokmen Trail Series lower trail arms
- Strongflex lateral arm (panhard bar) bushings
- Strongflex upper trailing arm bushings
Wheels:
- 16x8 et-10 Level 8 MK6's
- 285/75R16 Falken Wildpeak AT/3
Exterior:
- Morimoto D2 projectors retrofit with 5k Morimoto HID’s
- Panamera 2.0 DRL LED projector shrouds with Switchback LEDs
- Satoshi grille mod
- Sherpa Matterhorn MKII roof rack w/ 38" X6S light bar, MaxTraxx mount, & Hi-Lift mount
- Running board delete
- Slim window visors
- ARB 8x8 aluminum case awning w/ tent add-on
- RCI engine, transmission, and axle skid plates
Interior:
- RX8 leather front seat conversion
- Leatherique black leather dye for rear seats
- Black carpet replacement throughout
- Gray seatbelt swap from another 3rd Gen
- WeatherTech mats
- Full color conversion to satin black interior with light gray upper half
- Led bulb conversion for HVAC and gauge cluster
- Diff lock button light-up mod
- Clock mod so green matches the green led in HVAC controls
- Rear storage box/camp kitchen built by McKinsey Craft, modded by me to include black carpet dye, locking 36" sliders, & Tembo Tusk XL fridge slider w/ cutting board attachment
- Sherpa rear cargo base (removed the carpet underneath and it works perfect with the box)
- Rago rear racks
- Raingler full ceiling net (not installed)
Electronics:
- Pioneer AVH1440-NEX
- Alpine rear flip-down TV
- Pioneer 6.5” 2 ways front and rear (stock is 4" in rear, this is a huge upgrade in sound quality)
- Midland MTX275 GMRS w/ stubby antenna
- Uniden CB w/ 4' Firestik
Check out the build thread in my signature to get the full picture on a lot of the more "recent" work that's been done.
This has been a phenomenal adventuremobile for the wife and I, but we're downsizing for an upcoming move away from the Vancouver, WA area. I'm asking $13k OBO - lowballers can go pound sand.
You're also going to get a bunch of spare parts, including the interior dye and some aftermarket stuff that I never installed, so you'll be set for whatever plans you may think up down the road!
Thanks for looking!
