FS: 4th Gen Scion Radio swap harness / back up cam interface - socal
simple
Senior Member
I’ve had an aftermarket stereo for awhile, and I’m doing some spring cleaning so to speak.
Comes with:
pt546-00120-ad -antenna adapter, you will also need another metra adapter IF you want to use both the stock antennas
pt546-00120-ch -this is the main harness, 20 to 28 pin adapter, single cut wire in pic was not actually cut, that was added. That will be the reverse wire tap, so if you add a back up cam, you tap the reverse wire in your door sill and connect it to that wire so the camera will show you when you put the car in reverse.
pt546-74120-mc -this is the bluetooth mic
Auto Harness House interface for adding back up cam. Has the adapter so you can use either with the older or newer larger scion FRS radio.
35 shipped for the lot. Mic is SOLD
