FS: 5th Gen 2013 4Runner SR5 Premium | 4WD | AL | Bilstein/OME Lift, SPC UCAs, RCI Skids - 258k mi, $15k OBO
3point4par
Athens, AL Rust Free Rig $15k
Aftermarket parts are 50k mi old, only been off road twice in 3 years since upgrades
Routine oil changes and replacement air filters, maintenance logs since 94k mi
List of aftermarket parts
Suspension
Bilstein | OME Stage 2 RTR Lift Kit – 5th Gen 4Runner | FJ Cruiser (10-14)
Front Coil Configuration LD – Light duty coils, intended to be used under stock vehicle weight. Option 1: OME 2884: LD, 1.5″ lift
REAR COIL CONFIGURATION LD – Light duty coils, intended to be used under stock vehicle weight. Option 1: OME 2889: LD, 2″ of lift – 30% stiffer than factory
SPC upper Control arms
Rear Panhard Trac Bar
BOTCK- BOLT ON TRACKBAR CORRECTION KIT $205
Brake Lines
YM | 2003+ Toyota 4Runner | GX470 | GX460 | FJ Cruiser Extended Brake Lines - Front and rear extended brake lines - BRAKE LINE COLOR Smoked Black $135
Bump Stops
Front rear of lower control arms
Energy Suspension- 8.9104G REAR BUMP STOPS
Rear spring and frame
Energy Suspension 9.6104G Coil Spring Isolator Set
Energy Suspension Rear Coil Spring Bump Stop/Isolator 8.9105G
Wheeler's SuperBump Rear Bumpstop Set for 03+ 4Runner and 2007-2014 FJ Cruiser (WOR-306952)
Skid Plates
Full Skid Package Deal | 10-Present 4Runner
Material 3/16" Steel - Black powdercoat
Bumper Filler Plate | 10-Present 4Runner
Material 14 gauge steel
Catalytic Guard | 03-Present 4Runner / FJ / GX
Material 1/4" 5052 Aluminum - Raw Metal
Fuel Tank Skid Plate | 03-24 4Runner / GX
Rear Shock Mount Skids | 10-24 4Runner / FJ / GX
Lower Link Skids | 03-24 4Runner / FJ / GX
4Runner Differential Skid / 5th Gen / 2010+ × 1
Rock Sliders
Rock Sliders | 10-Present 4Runner
Top Tread Plate - Add Top Tread Plate
Finish Satin Black Powdercoat
Slider Angle 20 Degree Sliders (Standard)
Wheels
Method Bead Grip
706 | Method Bronze × 4 | 17x8.5 | 6x5.5 | 0/4.72" | MR70678560900
Lug Kit | 4 Wheels | Full Kit - Black × 1 | 6 Lug | 12x1.5 | EXTENDED | LK-W56015SEB ET
Tires
BFGOODRICH® All-Terrain T/A KO3 LT285/70 R17/E
EZ Flate C.A.S.E. 10.6 CFM Portable 12V Air and Hyperflex 4 tire inflator
Recovery
Ironman 4x4 America
Toyota 4Runner 2010+/Lexus GX460 Rated Recovery Points
MaxTrax Xtreme Boards, Orange (2)
Hi-Lift Xtreme Jack 48"
Exhaust
Flowmaster FlowFX Cat-back Exhaust System 717805
Granatelli Electronic Aluminized Mild Steel Exhaust Cutout System for 2 1/2 in. Single Exhaust (Slip-Fit)
Engine Bay
4Runner Engine Bay Accessory Tray - Driver Side / 5th Gen / 2010-2019 × 1
Backwoods Adventure Mods Windshield Fluid Reservoir Guard Skid Plate (10-23 4Runner)
Item #: TR17428
HPS Silicone Post MAF Air Intake Hose Kit; Black (10-23 4.0L 4Runner)
Item #: TR23504
Interior
ScanGauge III
Pedal Commander PC27
67 Designs 4RunnerRail
Yaesu FTM-400XDR Ham Radio Dual-Band Mobile 144/430MHz Transceiver
Roof Rack
LFD Off Road Ruggedized Aluminum Extrusion Crossbar - 5th Gen 4Runner × 3 and Traction Board Mount
Exterior
Spyder Toyota 4Runner 10-13 Projector Headlights
Maintenance Notes from iPhone
Oil Capacity and Type: 6.6 qts, Castrol Edge High Mileage 0w20 every 5k mi
Battery: 620 CCA, Model D35
Engine Oil Filter: NEW Wix 51348XP OLD Wix 57173XP
Engine Air Filter: Wix 49350
Cabin Air Filter: Wix 24483
5k mi service performed at 4,974 on 6/12/13
10k mi service performed at 10,303 on 7/26/13
15k mi service performed at 15,542 on 9/6/13
20k mi service performed at 20,443 on 10/29/13
25k mi service performed at 25,779 on 12/10/13
Oil and filter at 32,040 on 3/10/14
Oil and filter at 44,497 on 7/18/14
Oil and filter at 56,150 on 11/14/14
Oil and filter at 68,532 on 3/6/15
Oil and filter at 79,932 on 6/8/15
Oil and filter at 87,333 on 1/15/16
Oil and filter at 92,458 on 5/9/16
Purchase at 94k mi in 9/16
Oil and filter at 99,514 mi on 1/29/17
Windshield wipers at 99,554 mi on 1/30/17
Oil and filter at 109,353 mi 8/27/17
Engine Air filter at 111,608 on 10/21/17
Oil and filter at 116,446 mi
Tires (new) and Alignment at 119,737 mi
Oil and filter at 124k mi on 8/5/18
Engine Air filter at 124k mi
Tire Rotation and Balance at 125,417 mi
Windshield wipers at 126k mi on 10/18/18
Battery (new) at 129k mi on 11/18/18
Tire Rotation and Balance at 130,653 mi
Alignment at 130,988 mi
Oil and filter at 131k on 12/30/18
Rear Differential Fluid change at 131k mi
Cabin Air Filter at 132,636 mi
Transfer Case Fluid change at 133,500 mi
Brake Pads (front) at 134,523 mi on 3/19
Tire Rotation and Balance 135,734 mi on 4/20/19
Oil and filter at 138,200 mi
Engine Air Filter at 138,250 mi
Rotation, Balance, and Alignment at 141,080 mi on 9/18/19
Oil and filter at 145,915 mi on 1/11/19
Rotation and Balance at 146,158 mi on 1/18/20
Coolant Flush and Change at 146,158 mi on 1/18/20
Engine Air Filter at 150,247 mi
PCV Valve changed at 150,247 mi
Rotation and Balance at 151,239 mi on 6/3/20
Oil and filter at 151,934 mi
Rotation, Balance, and Alignment at 156,593 mi on 10/29/20
Oil and filter at 157,189 mi on 11/9/20
Rotation and Balance at 161,881 mi on 2/4/21
Tires (new) and Alignment at 162,384 mi on 2/12/21
Oil and filter at 162,634 mi
Engine Air Filter at 164,900 mi
Tire Rotation and Balance at 167,406 mi on 5/5/21
Oil and filter at 167,852 mi
Tire Rotation and Balance at 172,331 on 7/24/21
Oil and filter at 172,814 mi on 7/27/21
Engine Air Filter at 177,001
Rotation and Balance 177,147
Oil and filter at 177,518 on 10/23/21
Rear Brake Pads at 177,518 on 10/23/21
Oil and filter at 182,561 on 2/26/22
Rotation and Balance 182,600
Battery (new) at 184k mi on 4/22/22
Cabin Air Filter at 185,632
Brake fluid flush 186,000
Rotation and Balance at 187,939 mi on 7/2/22
Oil and filter at 187,955 on 7/3/22
Engine Air Filter at 189,058 on 7/30/22
End links, front at 192,500
Oil and filter at 192,966 on 10/29/22
End links, rear at 192,966
Rotation and Balance at 193,433 on 11/11/22
Oil and filter at 197,977 on 3/12/23
Rotation and Balance at 198,778 on 4/1/23
New brake lines, struts, shocks, and springs on 4/13/23
Alignment and right front wheel bearing at 199,278 on 4/14/23
Battery Check on 4/30/23
12.22V 665A Good-Recharge
SOH 100% SOC 38%
Alternator Check
Cranking Normal 10V
Loaded 13.84V No Loaded 14.08V
Battery Check on 5/7/23
12.34v 615A Good-Recharge
SOH 100% SOC 60%
Rotation, Balance, and Alignment at 200,743 on 5/17/23
Brake status
RF Caliper: 7mm Green/Yellow
RF Disc: 31 mm
LF Caliper: 7mm Green/Yellow
LF Disc: 31 mm
Alignment at 200,736 on 5/20/23
Engine Air Filter at 201,675 n 6/9/23
New tires at 201,683 on 6/10/23
Cabin Air Filter at 202,700 on 7/5/23
New windshield wipers at 202,780 on 7/7/23
Spark plugs and MAF Sensor Cleaner at 203,098 on 7/15/23
Oil and filter at 203,108 on 7/15/23
Rear diff fluid at 203,398 on 7/25/23
PCV valve, hood struts, and rear hatch struts at 203,893 on 8/4/23
Front brake pads 7mm, yellow/green
Rotor thickness 31mm
Tire Rotation at 207,700
Oil and filter at 208,095 on 11/26/23
Front brake pads and rotors at 208,600 on 12/10/23
Battery Check 2/3/24
12.22V 575A
SOH 100% SOC 38%
Good-Recharge
Oil and filter at 213,165 mi on 4/18/24
Tire rotation at 213,664 on 5/10/24
Engine Air Filter at 214,300
Oil and filter at 218,664 on 9/8/24
Rear brakes, rotors and pads at 218,744 on 9/9/24
Alignment on 9/10/24
Tire rotation at 219,569 on 9/27/24
Cabin air filter at 222k
New spark plugs at 223,500 on 1/1/24
Oil and filter at 223,706 on 1/5/24
Tire rotation at 225,183 on 2/15/25
Battery Check 3/8/25
12.04V 620 CCA
SOH 100% SOC 8%
Good-Recharge
Engine Air Filter at 225,946 mi on 3/8/25
Oil and filter at 228,735 on 5/17/25
Battery Check 5/17/25
12.15V
Health 84% 567 CCA
25% Charge
New fuel pump on 6/12/25
Tire rotation at 230740 on 7/8/25
New tie rods (inner and outer), LCA’s w/LBJ’s, and UBJ’s at 231,400 mi on 7/22/25
Alignment at 231,419 mi on 7/23/25
Oil and filter on 9/13/25 at 233,855
New tires at 235,956 on 10/29/25
Old tires were from 201,683 on 6/10/23 - went 34,273 mi
Front brake service needed, thickness check and lube especially passenger front - it squeaks 11/2/25 9mm Green Pad thickness
New Battery old one lasted from 184k mi on 4/22/22 and died 11/18/25 at 236k mi
Alignment on 12/3/25
Engine Air Filter, Oil and filter on 1/13/26 at 238,913 mi
Tire rotation on 1/15/26
Cabin air filter on 3/14/26 at 242,150 mi
Baxter Performance TS-501-BK, Oil and filter on 4/4/26 at 243,000 mi
Tire rotation on 4/4/26 at 243k mi
Tire rotation on 5/19/26 at 245,906 mi
Oil and filter on 7/3/26 at 248,880 mi
Tire rotation on 7/14/26 at 249,493 mi
Tire rotation on 8/24/26 at 252,402 mi
Windshield wipers on 8/28/26 at 252,626 mi
Engine Air Filter on 8/30/26 at 252,767 mi
Oil and filter on 9/20/26 at 254,370 mi
Tire rotation on 10/14/26 at 256,300 mi
Jyb
