FS - 5th Gen ARB Twin Compressor Mount (Pass Eng Compartment) - $115 to $150
So is there a mount for the 4th gen, ARB dual compressor with ARB 1 gallon tank?
Sorry to say no... there is not enough height to fit both on the 4th gen....
I do have one 4th gen. ARB twin compressor mount, with the ARB manifold mount, in stock currently if insterested (PM me if soo before it’s taken)...
Will this work with a smittybilt 2781 compressor on a 2018 ?
The smittybuilt one will not fit horizontally (I do not have actual dimension to be 100% sure) based on the one posted, but it would vertically...
However, the Viair 400p will work with my mount along with the ability of a 1 gallon tank (arb or Viair) and/or a manifold (arb or Viair)...
[MENTION=125603]bandi[/MENTION] --- on the mounts with. A single arb do you need to drill holes for mounting the compressor or just use 2 holes?
My plates are pre-setup for the twin, if someone specifically orders for the single, I provide additional holes for multiple mounting positions...
If you have a twin mount already and it does not have the single mounting holes, I'd use two existing holes, and just drill two more (as I am a little OCD), it would be fine with two bolts tooo...
Has anyone here used the ARB quick connect fitting with these mounts? It appears that there will be enough room but... I am currently waiting for Bandi to fab mine up and just trying to gather any other parts to have them ready.
Do you mean a quick connect out of the top of the compressor housing? If so, no I didn't fit on mine, mine was built for a 1gal Viair tank (option #1, IIRC), if it does fit it will be close. Maybe other options sit lower?
I ended up adding a viair 1 gallon tank and an outbound pressure regulator, so it wouldn't have made any sense in my case.
I know you said that you didn't get my PM, but now I'm wondering if you are getting any of my PM's. I responded back to yours, but haven't heard anything. I know your probably busy, just checking.
Thanks,
Yes, right out of the top. The ARB quick chuck doesn't extent too far. We will see once I get the bracket
FJ compressor mount
I wheel with a 2013 FJ owner who is in need of a driver side ARB compressor mount (he currently owns a single piston ARB), can you please provide a link to the product image.
Thanks in advance
Can you make a custom bracket, in my situation i want to use it for a air horn set up that haves a compressor and air tank. i have a 2014 4runner sr5. thanks
He already makes a bracket that has the ability to mount a dual ARB compressor and a 1 gallon air tank... What size air tank are you thinking? Is everything mounted together in your air horn setup?
my air tank its different from the vair tho that's why i was asking, mines have 4 mounting tabs. and the compressor its smaller then the arb
I gotcha! I have the mount for the Dual ARB and Vair compressor is the reason I was asking. I was trying to think for myself what might could be done to something like mine to make yours work. I will say this, if you do get a bandi mount, its well worth it! Solidly built, powdercoated black, with all the hardware. He does good work without a doubt!
I make adapters to run a 4 mount hole tank as in the ARB 1 gallon tank...
What tank do you have?
to be honest idk, its a universal tank i think and it haves two mounting tabs on each side of the tank. i just want to mount my compressor and tank in the same spot, and this seems like it would work perfect. is there anyplace i can send you pics of the set up?
Its identical too this one
