FS 5th Gen. Full Length Roof Racks by drabbits
Love the rack and really considering it, but the fairing with its 90 degree corners looks cheap. Maybe just a yakima fairing would fix all the issues. Mounts would work I'm sure.
The fairing is made from ABS plastic so you can just cut to your hearts desire. Just buy some more off eBay when/if you screw up.
I am already thinking of redoing mine with thicker ABS material since I now have experience in fabricating the brackets out of aluminum flat bar and can get any angle I want.
You guys all rule!
Thanks for helping [MENTION=89313]Shogun[/MENTION] with his wind fairing issue.
Silicone is not necessary due to the gooey factory loctite Toyota uses, BUT taking a 'safer than sorry' approach is never wrong.
[MENTION=50210]KVA[/MENTION], looks like I found someone to make wind fairing brackets guys!! :madgrin:
Just kidding man.
Sounds like 3/16th ABS might be the way to go, if you haven't already purchased some, let me see if I can get a few pieces from my plastic supplier.
You guys all rule! /QUOTE]
I think you're the favorite around here, not us! Sounds like you've got tons of interest from lots of individuals right now. Just curious what an approximate wait time might currently look like for a rack? I'm not in a rush at all, but I definitely want to get a hold of one eventually if I can!
Great work!!
... looks like I found someone to make wind fairing brackets guys!! :madgrin:
Just kidding man.
Sounds like 3/16th ABS might be the way to go, if you haven't already purchase some, let me see if I can get a few pieces from my plastic supplier.
I have respect for you now...it is very time consuming to work with aluminum. Even spoke to Demello about how they handle their aluminum and basically heat it up to 180 degrees and let it cool, then you can bend all you want...no more brittle aluminum. BTW - use a torch to heat it up - way faster.
If you get the 3/16 ABS I would love to try it. I can even get it perfect with the brackets and then make you a set that you can use as the master. I used thicker flat bar as well but it is not needed - just all I could get at the time.
Yeah I'm kind of torn between the single LED bar or breaking up the space with multiple lights. Wiring would be more complicated but I kind of like the look better... I've been looking at what other folks have on their gobis while I anxiously await my rack to get fabbed haha
Just read all 20 pages of this post again.
Cannot wait for my package from Alex [MENTION=68079]drabbits[/MENTION] to arrive!
To those who have installed the roof rack already:
any thoughts on a lighting set up?
I customized so I only have about 38" to use...otherwise a 40" would work fine - single or double row.
Adding multiple lights is easy and no additional wiring runs unless you want them all individually switched.
Does anyone have a picture of lights mounted on the rack? I'm interested but wanted to see what the front looks like to mount some lights.
Light will be really easy to mount and pictures will look like any other rack out there based on the flavor of lights chosen. I will have to mount mine a little different as I am trying to fit a 40" within 38" of space...lol
...remember that you will need to drill holes to run wire...unless you will zip tie to the outside
These are the flavors I've been looking at. I am hoping to pull the trigger on one in the next couple of weeks. (these are in order of my preference)
I'm open to any input anyone has on any of these bars. (or others)
The Retrofit Source MORIMOTO X.BAR 40" $1,000
Morimoto X.BAR 40 - Off-Road Lighting
Rigid Industries SR2 40" - Combo $1199
Rigid Industries LED Lighting | Leader in Off road LED light bars, truck LED lights, Marine LEDs, and Industrial LEDs
VisionX Evo Prime 39" $1,749
LED, HID, and Halogen Lighting | Off Road Lighting | Offroad LED Lighting | Mine Lighting | Mining Lighting | Marine Lighting | Agriculture Lighting | Defense Lighting | Industrial Lighting | Commercial Lighting | Automotive Lighting
Black Box Logistics H Series 40" $399
Black Box Logistics - H Series
(link is to the 30" bar, they dont list the 40 on their site)
This one looks really interesting (looks cool too!) - though for a grand I would worry this would get stolen rather quickly.
I agree. I've been looking at irregular bolts to try and use. Or some way to 'lock' it in place. Maybe even using some type of quick disconnects (mounting and wiring) so that I will only have it on when I know I am going to use it.
Look Here or do a search within the site for security bolts.
After looking through the LEDs, I am really liking the H Series from Black Box. Did you find out if they are coming out with a 40"?
I sent them an email to see...
Yeah, I reached out to them. They said they would have to special order the 40" bar and it would probably take a couple of weeks. And he quoted me $399 to my door. What I really like, I think it's neat, is the wireless remote. And how you can turn on the flood lights separate from the spot lights. Or both on at the same time.
I'm assuming these are chinese bars (they don't mention it specifically on their site) but appears that they have tested these out pretty rigorously.
EDIT (add info from email):
What are the specs for the 40" bar?
51 LEDs, 258W, 42" total, 20640 raw lumens, 18 3W CREE outer LED's 3W (each side, dual row), 15 10W CREE LEDs (center, single row)
How many 10W LEDs & 3W LEDs?
15 - 10W CREE LED's
18x2 - 3W CREE LED's
Out of curiosity, can the 3Ws be amber LEDs?
No, we cannot change the color of the LED's, but we will have lens covers you can use that slide and lock in. The H Series come with black lens covers already in the price, so you will be able to see for yourself the style of lens covers. You can use a clear cover in the middle, and amber on the ends. These should be available for in by March.
Do you off road so much at night to need a 40" bar? I would think like 4 Rigid D2's would be plenty for half the cost.
charlesz
