FS: Airaid Throttle Body Spacer 03-04 V8
24runners
This will fit the 03-04 4Runner/Tundra V8's...It will not fit the 05 4Runner due to the different throttle design of the 05+ 4Runners
It cost ~$110 off ebay...I dont need this so if anyone can use it, make me an offer :)
it is brand new in the box
---details----
Airaid PowerAid Throttle Body Spacer
Part #: 510-537
FITS THE:
2003-2004 TOYOTA TUNDRA 4.7L V8
2004 TOYOTA 4RUNNER/4 RUNNER 4.7L V8
HP & Torque: 5-8HP/ 13 ft. lbs. Torque
Evergreen Performance POWERAID throttle body spacers distance the stock throttle body from the intake manifold creating a higher air intake velocity. This effect creates a substantial increase in torque output. In addition the POWERAID feature a unique swirled inner wall to mix the air better with the fuel as it passes the fuel injectors. By doing so the engine can burn more of the air and fuel being dumped into the cylinders making the engine more efficient. The end results are a stronger, more even torque curve and increased fuel mileage. Easy to install and smog legal the POWERAID is an excellent value.
Evergreen has got you covered! POWERAID
