FS: Blue Sea Remote Battery Switch- 7700 -12V DC 500A, $100 Charleston, SC
Gwain
Used less than 3 months. This sells for $157.04 on Amazon. Asking $100, plus shipping if necessary.
500 Amp magnetic latching switch provides high amperage switching under load, manually or from remote locations. This is not an Automatic Charge Relay (ACR). It is a battery switch. Great for manually combining batteries or as a fuse bypass for winch operations.
Manual override knob provides an added level of safety allowing control with or without power and offering LOCKED OFF capability for servicing
LED output to remotely indicate switch state - requires optional LED
3∕ 8"-16 tin-plated copper studs for maximum conductivity and corrosion resistance
7∕ 8" (22 mm) stud length accepts multiple cable terminals
Label recesses for circuit identification
Specifications
-Control Circuit Connection -Tinned
-Nominal Voltage - 12V DC
-Manual control switch provides an added level of safety allowing control with or without power, and offering LOCK OFF capability for servicing.
-Coil Function Auto releasing provides 500A switching and features of current ML Remote Battery Switches, but can be controlled with SPST or SPDT switch for applications where a normally open relay is desired.
minearcj33
