FS: "Jitters" 1998 4Runner, Cheyenne WY, $5200 OBO
1985taylor1925
Senior Member
Sold
Sold it on friday 9/15/17 for $4750.
1998 4Runner - Black - SR5 - 4X4 - 3.4L - 4:10 gears - Auto - 248500 miles - $5200 OBOB - located in Cheyenne, WY, about 45 minutes from Ft Collins, Colorado
Well, the time has come for me to sell my beloved "Jitters", unfortunately. I needed something more comfortable and practical for highway commuting. So I ended up getting a 2001 Lexus RX300 really cheap at an auction, which only needed some minor work to get it in good running condition. Selling the 4Runner is a really difficult decision, and I'm only doing it because I simply can't afford to hold onto it right now. I'm sure I will regret this in the near future. But a chronic battle with Lyme disease has forced me to change up my priorities. Anyways . . .
I dont think I need to explain too much about the truck, as my build thread is here. You can see most of what Ive done to it over the years.
http://www.toyota-4runner.org/3rd-gen-t4rs/73462-few-pictures-my-runner.html
- Heat and AC work
- 4X4 perfect
- Power locks, windows
- Interior is very good
- Exterior still looks very good
- No body rust
- Engine, tranny, transfer case, front and rear diffs all good
The bad
- Some surface rust on the undercarriage, nothing bad, nothing even close to structrual
- Paint isnt perfect. It's 20 years old
- Parking brake lever is not currently attached. I'm working on it
- Otherwise everything works
I'll just copy and paste the first section of my thread as a quick reference to maintenance and mods.
As of today: Updated 8/30/17
248500 miles
Last oil change: 247000
Mods and Add-on's
Exterior
- Clear corner and bumper lenses
- LED tail lights
- Pre-fatlip bumper painted OEM black (purchased from blcktpgsr)
- Rear bumper ends painted OEM black (purchased from BanditRunner) thanks BanditRunner!
- Front grill flat black (just repainted)
- Sotashi mod with Tundra Toyota emblem
- Liscense bezel painted OEM black
- Skid plate painted aluminum metalic (just repainted)
- Westin in channel vent visors
- Updated SR5 flares to wide sport flares
Interior
- Interior dash trim painted Rust Oleum semi-gloss black
- Husky floor liners, front, back and cargo (one of the best purchases I've ever made)
- Kenwood KDC-BT955HD Head unit (AUX, bluetooth, HD radio, CD, etc)
- Infiniti Reference speakers
- Alpine power pack amp
- CNC cut stainless steel "4RUNNER" door sills
- Custom made cup holder! Best mod ever
- Rattle Trap and Noico sound deadened throught the entire vehicle (front and rear floor, hatch, all 4 doors, hatch door)
- Closed cell foam decoupler on many of the interior panels
- Limited leather door panel swap (purchased from DeathCougar)
- Auto vinly center console cover
- 99 center console swap for cup holders
- Steering wheel cover
Suspension/Drive Train
- (Rear) 99 Coils, stock shocks
- (Front) 99 coils with Tacoma Bilstein 5100's on lowest setting
- Safari LTD Steering Rack
- Sway Away poly steering rack bushings
- Sway Away poly front and rear sway bar bushings
- @MStud front adjustable front links
- Rear diff breather mod
- EBC performance brake rotors and pads
- 2016 4runner wheels mint condition
- 265/70r17 Cooper Discover AT tires @ 230k
- Sway away lca poly bushings
Engine/Performance
- "Hole in the air box" (deck plate) mod
- ISR mod
Lighting
- 99+ glass Headlights from Certifit
- Hella Micro DE custom mounted fog lights
- Interior LEDs (center consol, map lights, speedo and odomoter indicators)
- LED aftermarket tail lights
- Clear corners and bumper lenses
- Phillips super white headlights
Maintence/OEM parts
- New rear cone bump stops @ 165k (taken off when lc coils installed)
- Moble 1 high mileage synthetic and OEM oil filters every 4 - 5k
- OEM air filters every 10k
- OEM Injector #3 @ 165k
- OEM spark plugs @ 165k
- Amsoil synthetic rear diff oil @ 166k
- Tranny oil full flush and refill @ 175k
- OEM fuel filter @ 173k
- OEM inner tie rods @ 170k
- OEM tie rod ends @ 168k
- OEM upper and lower ball joints @ 170k
- OEM remanufactured steering rack @ 173k
- Seafoam in oil and pcv valve @ 186k and 190k
- New Denso Radiator and Toyota Red coolant @ 187600
- OEM remanufactured drive/pass cv's @ 189300
- OEM steering column shaft sleeve bushing @ 189300
- Replaced steering intermediate unit with lower mile (107k) unit @191000
- OEM reman cv's (again) @ 203000
- Reman alternator @ 212000 11/1/14
- New Safari LTD Steering rack @ 220000
- Energy suspension rack bushings @ 220000
- New Beck/Arnley upper ball joints @ 220000
- New OEM inner tie rods and rod ends @ 220000
- Lower mileage steering shaft intermediate unit (to rack) @ 205000
- Amsoil front diff oil @ 215000
- New OEM front wheel bearings @ 220000
- Greased all drive shaft fittings @ 22000
- OEM spark plugs @ 225000
- EBC brake rotors and pads @ 237500
- Eastern Cat converter @ 237500
- Duralast rear u joint @ 237000
- Sway Away lower control arm bushing @ 243000
- OEM rear shocks @ 243500
- OEM valve cover gasket @ 244500
- OEM spark plugs @ 244500
- OEM intake manifold gaskets @ 244500
- OEM passenger lower ball joint @ 245000
- OEM used cv axles @ 245000
- OEM inner tie rods @ 245000
There are probably many other maintenance items I've done, and just forgot to add them at the time. Basically, I have maintained my truck very well.
Pictures as it sits now.
Wow, I agree, you'll regret it.
Yes, I know for a fact I will. When I inevitably buy another one in the future I will have a lot of work ahead of me to make it like "Jitters". I am only selling because I got a Lexus RX cheap at an auction, and it is the commuter that I need for now, while I need the money to pay med bills. I'll actually come out ahead after selling the 4Runner. But yeah, it's the first vehicle I purchased with my money. I've owned it for seven years. Taken from Wisconsin to wyoming 5 times. It's the vehicle I learned to do auto work and maintenance with. Became a hobby and obsession like pretty much all of us on this forum. I am definitely feeling the sentimental attachment at this point. But, I know I'll be back in the future when things calm down with my Lyme disease. I'll probably end up tracking down my truck and buying back.
H.Sikina
