FS/T: Audio Equipment, Subs, Amps, Install... OR
UnderFire
Thought I'd list some of the misc. Car Audio equipment I've had laying around a while to see if any of you guys might be interested in it.
What I have...
A pair of like new JL 12w3v3's, they are single 4 ohm, and in excellent shape, only installed once and probably saw less than 10 hours of play time before being shelved. Great for a lot of controlled output from a small space. I'm thinking 260$ Shipped for both, don't ant to split these up.
Specs:
Subwoofer Size - 12"
RMS Power Handling - 500 watts
Voice Coil(s) - Single
Impedance (Per Voice Coil) - 4 ohms
Frequency Response - 22 - 200 Hz
Sensitivity - 87.15 dB
Xmax (millimeters) - 13 mm
A matching pair of Kenwood KAC-7204 amps. Same basic story as the JL's, only installed once, not very much playtime before they were shelved. Still have the beauty covers installed and are in awesome shape. 180 + Shipping for the pair, may be convinced to split these up.
Specs:
• 250 Watts x 2 (2 ohm)/500 Watts x 1 (4 Ohm Bridged)
• High Quality Speaker Level Input
• High-pass (12 dB per octave) and low-pass (24 dB per octave) filters variable from 50 to 200 Hz
• Variable Bass Boost Control(0-18 dB at 40 Hz)
• Cooling Fan
• MOSFET power supply
• Speaker-level inputs with signal sensing turn-on
• Preamp-level inputs and outputs
• Fuse rating: 40A x 1
• 13-3/4"W x 2-1/4"H x 9-3/8"D
A brand new 6" PrecisionPort Aero, bought this and ended up never needing it, still new in the box. 40$ Shipped anywhere (Paid around 55$)
An Orion Cobalt 265XP, nice little old school budget amp, around 250W RMS when bridged, perfect for a single entry level sub, or a set of components in the doors. 30$ + shipping on the little guy.
Also have a ton of random install stuff laying around, battery terminals, fuse holders, wire, RCA's, EVERYTHING, if you need it, I probably have it, so just ask.
I like trading too, so just offer up if you have anything, I'm willing to consider basically any trade.
Tx470
