Fuel injector o rings?
enapa
I need to get a complete set of o rings and can't for the life of me find them. The ones I got at o'reilly are too big and leak like crazy. Anyone? I've checked all the usual toyota parts websites and no luck.
2000 Limited 3.4 4x4 if that matters.
I've had good luck matching o-rings at Napa in the past. But for injector o-rings I'm not sure... dealership would be your best bet by far if they have them in stock but would be the most expensive option.
Thanks I will check Napa.
Anyone else?
Well Napa has the same Fel Pro FPG ES70600 that I got from o'reilly. They don't fit properly.
I used these o-rings from O'reilly and they worked fine. They felt a little loose compared to the originals but they don't leak. Maybe you got a faulty set?
Well I guess I get to take it all apart and try again. I will just lube and lube and lube and cross my fingers.
delislerebecca
