fuel problem i think
culli
hi everyone, im new to this so please bare with me.
i have a 92 4runner 3.0 v6.
i have only had it for a couple of months and have been driving mostly on the road, but on the weekend i went offroading and all was fine, awesome in fact. then i got back onto the main road and started my drive home and it started jumping and bunny hopping anywhere from 3500rpm and above, i pulled over and turned the car off, started it again and it drove fine for awhile then started doing the same thing, once again i turned it off, restarted it and it drove fine for awhile and this kept happening the whole way home.
once i got home and let it sit for an hour i took it for a drive round the streets and it drove like a dream.
could anyone tell me if this could be a contaminated fuel tank? my idea was that while offroading the fuel in the tank had been slushing crap around and when i finally got out on the road and got the revs up a bit the pump was sucking it up and blocking any access.
could this happen or does this sound right? cheers for any help, input, or suggestions anyone might have.
First if you didn't figure out that this is in the wrong section for your year and motor, i would try posting it in the 2nd gen since they will know your vehicle better. But you really need to do some testing and see where the problem is. I would personally guess it is an ignition problem. Possible ignitor or coil. Seems like one of them is failing after it gets warm. I would warm it up and put a timing light on the plug wires and have someone rev it up and see if the ignition in breaking up. To test the fuel issue, i would put a fuel pressure gauge on it and check that its steady pressure even above 3500RPM or whenever the engine start to cut out.
Jhunt
