4'running'26
Thanks, guys.
So I just had to recheck my connections due to an evap code. Turns out it was the smaller connection to the canister that wasn't clipped in properly and popped off. My wife dropped the tank too far with the jack when helping me and my pump stopped working. Reading about the hatch I pulled my 2nd row to see if the hatch was there. 2011 limited 4runner has the hatch. Luckily the plug just popped off.
I've dropped the tank twice now and the access hatch is nice but not required. The 2nd row seats have 4 bolts in the rear covered by 2 covers that pop off with the seat all the way forward. The front has 1 bolt and 1 nut covered by two plastic covers. I had to make 2 small cuts in the carpet to not have to take out more seats.
If you take off the straps and lower the tank slightly you can barely get an arm up to remove the plug but it is difficult. I had to pull my muffler to get enough room, you could also pull your driveshaft.
The 2 evap connectors (i think they are both evap) are not accessible from the hatch, only the power plug. The big connection is a pinch and pull type that is difficult and you might need to use a screwdriver to release the clips. The smaller one has a clip similar to the fuel lines; the two tabs are pinched and pushed through and released with a pick screwdriver on the other side. Lowering the tank a bit and then taking them off works but again there is not alot of room.
The tank has to be dropped to remove the fuel pump and, in my case, I dropped the tank to have access to replace the rear brake lines and undercoat the bottom and frame.
