have you eliminated the possibility of a vacume leak?
if the junk in the tank got though the strainer and made it through filter then it could clog a injectors and cause a problem i would suggest that pull them out and clean them really good. there are how too videos on youtube.
If this helps the problem doesnt totally fix it you may want to invest in new injectors.
If cleaning the injectors does not help the issue make sure the MAF and the TPS are calibrated and worrking proper.
If all that is good it may be possible that the CPU has shorted but unlikely the 4runner CPU is known to be really good. so i hope the injectors are the issue.
I sometimes get moisture in my fuel lines (usually when the temp starts changing, and freezes overnight) It'll do the same thing until it's up to temp, or at least been running a few minutes. Go get some HEET (yellow bottle I think) and dump that in your tank then top it off with gas.
