the_dingman
So it's not been since early December that my 4Runner ran properly... I've gone through lots of troubleshooting, and I thought I had it pegged at the fuel injector that had me with a dead cylinder.
Problem:
I sent my fuel injectors in to RC Engineering, and they came back a few days ago looking brand new (the went in with rust and peeling paint, now they look like brand new metal). I put everything back together, and my engine did start, and runs if I keep the throttle up, but dies on idle. It sounds perfect for a second after starting, then gets rough. RC said one of my injectors was 'dripping'.
Possible problem:
I'm leaking fuel out of the 2nd and 3rd injectors, after removing them, it seems that I pinched the seals, and they need to be replaced.
First question:
Would a 'dripping' injector cause a dead cylinder?
Second question
Can my leaking injectors (leaking between the fuel rail and the injectors) be the current cause of running rough. In other words, can low fuel pressure before the injectors cause the engine to run rough?
Third question:
Is there a way to pressurize the fuel system without the intake plenum installed? I'd like to see if there are any leaks after replacing the seals before putting it back on.
Fourth question
I may still have a dead first cylinder. So far I've replaced my plugs and wires, distributer cap, and had my injectors rebuilt and tested. I've also performed a compression test, with cylinders 2, 3 and 4 testing at 180psi, and 1 (the one that was dead) at 184. I know the spec is for 172... Is it possible that my compression being too high it the problem?
Beyond spark plugs, wires, distributer cap, and fuel injectors, what could be a possible problem? What's the best way to find out if my injector is getting a signal?
Problem:
Possible problem:
First question:
Second question
Third question:
Fourth question
