Fuel Tank Relocation (and new Rear Bumper design)
No sir, trying to squeeze in a couple of hours tomorrow to test fit the driver's side on the prototype bumper, then I can submit the production order.
(which means I'll be taking client orders later this week!) :nod:
At the moment, SS makes the rear pair, but Energy Suspension makes the entire truck set. I think DuroBumps has them in the queue though..
Is your first run of bumpers specifically for those with a body lift? I don’t have a body lift.
Yes sir - haven't designed the non-BL variant yet. (every plane changes for non-BL, so there's literally no common parts, save the upcoming swingout hinge assembly)
I’ll be patiently waiting for the non bl one.
Did you ever get a guesstimate in weight?
Does your bumper design have a receiver built in?
The bumper has provisions for a receiver, but a third-party receiver (like you'd buy from e-trailer or similar) will not be included in the bumper purchase for overall cost, shipping, and liability reasons.
Check it out:
Maybe I missed it somewhere, but do you have a link for the specific lights you spec'd the rear holes for? [MENTION=28464]eimkeith[/MENTION]
Oh sorry, hadn’t mentioned that yet - they’re for Rigid Industries IGNITE back up light kit - 20641.
- to be mounted behind the bumper. :)
The bumper has provisions for a receiver, but a third-party receiver (like you'd buy from e-trailer or similar) will not be included in the bumper purchase for overall cost, shipping, and liability.
So there will be structure there for like a 6” or so receiver to be welded in it looks like? I actually have one waiting then. I was going to build a front bumper with a hidden receiver and I bought the little 6” long receiver from e-trailer and never used it. I also have some 2.5” square .250” wall material in my metal rack that is the same Inside dimensions as a receiver is.
Is the only additional piece needed for it to hitch compatible the receiver, or is there additional support that will need to be added? I probably missed it, but will the bumpers be pre-bent just requiring welding?
To be hitch-compatible you'll need to provide a ~40.5" length of 2x2" tubing (welds in between the supplied bumper mounts) and a short receiver.
That's correct. There will be 5 pre-bent brackets, 2 recovery points, and 3 pre-bent bumper parts in the bumper kit. (and some hardware)
You'll need to provide the OEM running board cover for the top of the step (this covers the access holes and finishes off the top of the bumper - I'll give measurements for how to trim it to fit) and the aux reverse lights (if you choose to run them)
Also Note:
  • The bumper requires the rear cross member from my fuel tank relocation bracket kit as its basis, so if you don't have one of my kits you'll need to add a crossmember to the order.
  • It also requires a 1" body lift, and I strongly advise the use of poly body bushings on the rear body mounts to minimize flex & potential body contact when wheeling.
  • And, you will need to cut out the pinch weld in the rear of the wheel well on each side for clearance, as the bumper is designed to provide full articulation with 35" tires.
To be hitch-compatible you'll need to provide a ~40.5" length of 2x2" tubing (welds in between the supplied bumper mounts)and short receiver
The 40.5” tube runs left to right and the receiver will butt up against it and also need to be welded at the face of the bumper I assume?
Receiver goes over the top of it (post 350). The bottom of the receiver is notched to reduce the overall height
Sent from my iPhone using Tapatalk Pro
got of quick video of [MENTION=84796]Coward[/MENTION] spinning a 315 at full stuff on the factory bump with the prototype bumper installed:
(you can hear the tread clicking on the untrimmed SR5 flare)
BygLU5ng5V_
<blockquote class="instagram-media" data-instgrm-permalink="https://www.instagram.com/p/BygLU5ng5V_/" data-instgrm-version="12" style=" background:#FFF; border:0; border-radius:3px; box-shadow:0 0 1px 0 rgba(0,0,0,0.5),0 1px 10px 0 rgba(0,0,0,0.15); margin: 1px; max-width:540px; min-width:326px; padding:0; width:99.375%; width:-webkit-calc(100% - 2px); width:calc(100% - 2px);"><div style="padding:16px;"> <a href="https://www.instagram.com/p/BygLU5ng5V_/" style=" background:#FFFFFF; line-height:0; padding:0 0; text-align:center; text-decoration:none; width:100%;" target="_blank"> <div style=" display: flex; flex-direction: row; align-items: center;"> <div style="background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 40px; margin-right: 14px; width: 40px;"></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 100px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 60px;"></div></div></div><div style="padding: 19% 0;"></div> <div style="display:block; height:50px; margin:0 auto 12px; width:50px;"><svg width="50px" height="50px" viewBox="0 0 60 60" version="1.1" xmlns="https://www.w3.org/2000/svg" xmlns:xlink="https://www.w3.org/1999/xlink"><g stroke="none" stroke-width="1" fill="none" fill-rule="evenodd"><g transform="translate(-511.000000, -20.000000)" fill="#000000"><g><path d="M556.869,30.41 C554.814,30.41 553.148,32.076 553.148,34.131 C553.148,36.186 554.814,37.852 556.869,37.852 C558.924,37.852 560.59,36.186 560.59,34.131 C560.59,32.076 558.924,30.41 556.869,30.41 M541,60.657 C535.114,60.657 530.342,55.887 530.342,50 C530.342,44.114 535.114,39.342 541,39.342 C546.887,39.342 551.658,44.114 551.658,50 C551.658,55.887 546.887,60.657 541,60.657 M541,33.886 C532.1,33.886 524.886,41.1 524.886,50 C524.886,58.899 532.1,66.113 541,66.113 C549.9,66.113 557.115,58.899 557.115,50 C557.115,41.1 549.9,33.886 541,33.886 M565.378,62.101 C565.244,65.022 564.756,66.606 564.346,67.663 C563.803,69.06 563.154,70.057 562.106,71.106 C561.058,72.155 560.06,72.803 558.662,73.347 C557.607,73.757 556.021,74.244 553.102,74.378 C549.944,74.521 548.997,74.552 541,74.552 C533.003,74.552 532.056,74.521 528.898,74.378 C525.979,74.244 524.393,73.757 523.338,73.347 C521.94,72.803 520.942,72.155 519.894,71.106 C518.846,70.057 518.197,69.06 517.654,67.663 C517.244,66.606 516.755,65.022 516.623,62.101 C516.479,58.943 516.448,57.996 516.448,50 C516.448,42.003 516.479,41.056 516.623,37.899 C516.755,34.978 517.244,33.391 517.654,32.338 C518.197,30.938 518.846,29.942 519.894,28.894 C520.942,27.846 521.94,27.196 523.338,26.654 C524.393,26.244 525.979,25.756 528.898,25.623 C532.057,25.479 533.004,25.448 541,25.448 C548.997,25.448 549.943,25.479 553.102,25.623 C556.021,25.756 557.607,26.244 558.662,26.654 C560.06,27.196 561.058,27.846 562.106,28.894 C563.154,29.942 563.803,30.938 564.346,32.338 C564.756,33.391 565.244,34.978 565.378,37.899 C565.522,41.056 565.552,42.003 565.552,50 C565.552,57.996 565.522,58.943 565.378,62.101 M570.82,37.631 C570.674,34.438 570.167,32.258 569.425,30.349 C568.659,28.377 567.633,26.702 565.965,25.035 C564.297,23.368 562.623,22.342 560.652,21.575 C558.743,20.834 556.562,20.326 553.369,20.18 C550.169,20.033 549.148,20 541,20 C532.853,20 531.831,20.033 528.631,20.18 C525.438,20.326 523.257,20.834 521.349,21.575 C519.376,22.342 517.703,23.368 516.035,25.035 C514.368,26.702 513.342,28.377 512.574,30.349 C511.834,32.258 511.326,34.438 511.181,37.631 C511.035,40.831 511,41.851 511,50 C511,58.147 511.035,59.17 511.181,62.369 C511.326,65.562 511.834,67.743 512.574,69.651 C513.342,71.625 514.368,73.296 516.035,74.965 C517.703,76.634 519.376,77.658 521.349,78.425 C523.257,79.167 525.438,79.673 528.631,79.82 C531.831,79.965 532.853,80.001 541,80.001 C549.148,80.001 550.169,79.965 553.369,79.82 C556.562,79.673 558.743,79.167 560.652,78.425 C562.623,77.658 564.297,76.634 565.965,74.965 C567.633,73.296 568.659,71.625 569.425,69.651 C570.167,67.743 570.674,65.562 570.82,62.369 C570.966,59.17 571,58.147 571,50 C571,41.851 570.966,40.831 570.82,37.631"></path></g></g></g></svg></div><div style="padding-top: 8px;"> <div style=" color:#3897f0; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:550; line-height:18px;"> View this post on Instagram</div></div><div style="padding: 12.5% 0;"></div> <div style="display: flex; flex-direction: row; margin-bottom: 14px; align-items: center;"><div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(0px) translateY(7px);"></div> <div style="background-color: #F4F4F4; height: 12.5px; transform: rotate(-45deg) translateX(3px) translateY(1px); width: 12.5px; flex-grow: 0; margin-right: 14px; margin-left: 2px;"></div> <div style="background-color: #F4F4F4; border-radius: 50%; height: 12.5px; width: 12.5px; transform: translateX(9px) translateY(-18px);"></div></div><div style="margin-left: 8px;"> <div style=" background-color: #F4F4F4; border-radius: 50%; flex-grow: 0; height: 20px; width: 20px;"></div> <div style=" width: 0; height: 0; border-top: 2px solid transparent; border-left: 6px solid #f4f4f4; border-bottom: 2px solid transparent; transform: translateX(16px) translateY(-4px) rotate(30deg)"></div></div><div style="margin-left: auto;"> <div style=" width: 0px; border-top: 8px solid #F4F4F4; border-right: 8px solid transparent; transform: translateY(16px);"></div> <div style=" background-color: #F4F4F4; flex-grow: 0; height: 12px; width: 16px; transform: translateY(-4px);"></div> <div style=" width: 0; height: 0; border-top: 8px solid #F4F4F4; border-left: 8px solid transparent; transform: translateY(-4px) translateX(8px);"></div></div></div> <div style="display: flex; flex-direction: column; flex-grow: 1; justify-content: center; margin-bottom: 24px;"> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; margin-bottom: 6px; width: 224px;"></div> <div style=" background-color: #F4F4F4; border-radius: 4px; flex-grow: 0; height: 14px; width: 144px;"></div></div></a><p style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; line-height:17px; margin-bottom:0; margin-top:8px; overflow:hidden; padding:8px 0 7px; text-align:center; text-overflow:ellipsis; white-space:nowrap;"><a href="https://www.instagram.com/p/BygLU5ng5V_/" style=" color:#c9c8cd; font-family:Arial,sans-serif; font-size:14px; font-style:normal; font-weight:normal; line-height:17px; text-decoration:none;" target="_blank">A post shared by J Keith Walters (@eimkeith)</a> on <time style=" font-family:Arial,sans-serif; font-size:14px; line-height:17px;" datetime="2019-06-09T20:44:03+00:00">Jun 9, 2019 at 1:44pm PDT</time></p></div></blockquote> <script async src="//www.instagram.com/embed.js"></script>
I'm now taking pre-orders, guys - check it out.
Awesome Keith! Congrats on getting these bumpers to the masses!
I’ve always planned to custom design and build my own rear bumper, but I’ve been leaning more and more toward buying one recently. There is so much thought and purpose behind your design I think anyone would be a fool to choose something else.
When you get your first run of non-BL bumpers with the option to line up with the limited flares, you can count on me to purchase one!
Thanks for the kind words!
I'm actually releasing a non-BL mount kit as an add-on later in the year. The flare extensions will be add-ons as well. This allows me to maintain the same base bumper for all scenarios and keep the price down for you guys.
Ha, you’re making this really tempting to pre-order now...
