I just finished roughing everything in. I franken-fillered it with the stock rubber and steel fill tubes cut up and hose clamped together. It doesn't look to crazy lol. I was planning on plumbing the fill vent into the Ford breather on top of the tank. How did you run your vent that you think it is causing a leak out the cap?
There are a bunch of different problems with the way that I plumbed in the tank, I dropped it out to do it right.
- The Ford vent doesn't vent the tank fast enough to fill the tank with gas, gas keeps building up in the filler and runs back out onto the ground.
- Plumbing the Ford vent to the filler vent doesn't vent the tank when it gets hot, I have had gas sprayed on my hand when I opened the cap because it was pressurized.
- When the vehicle is at a 45 or more angle, gas will run up to the filler cap and eventually go through. This is a non-issue if you're not going rock climbing or steep hills.
Now I have to drop the tank out, make sure there's no gas/vapors left in it, and find someone to weld on the thin sheet metal
