Fuel Tank Relocation (and new Rear Bumper design)
I'm in the parts collection process of this project.... the bronco graveyard no longer has the upper straps.
what did you use? please advise?
I went to a Pick-A-Part to get the upper straps... I brought the wrong tools so I had to cut them out of the frame with a sawsall. Wish I had seen those Dorman parts, those do look exactly like the correct straps, but I only paid $10.
[MENTION=106706]MN4runnerman[/MENTION]: I should have clarified that I want to run dual tanks, so I can't cut out my stock filler. Does anyone know of a place to mount a second filler in the wheel well or something?
I can’t remember who made their filler to work for both tanks. Some people have used those landcruiser ones that you have to donate your kidney for. But I swear someone made their own dual filler neck and it looked good. Dirtco maybe??? I’m not on here as much anymore sorry. I guess read through the threads related to this and see if you can find it.
MN4runnerman I should have clarified that I want to run dual tanks, so I can't cut out my stock filler. Does anyone know of a place to mount a second filler in the wheel well or something?
Dirtco had an auxiliary tank, but he ended up using a second filler and vent for the second tank. It's in this thread: Auxiliary Fuel Tank
I’m thinking about retrofitting a Bronco tank; more than likely the 25 gal.
Think your kit would work with it?
What about the 38 gallon extended range F150 tank? Product same length and width as the normal F150 tank but 13.75" deep instead of 8".
F150 tank (19 gallon) 34 3/4 x 27 x 7 7/8
F150 tank (38 gallon) 34-3/4 x 27 x 13-3/4
Bronco tank (25 gallon) 31 7/8 x 22 1/4 x 12 3/4
Weight and depth.
3/16” Bumper with dual swing out (35 and two jerry cans), and (thinking about) rear mount winch.
25 gal is 157.5 lbs. 38 gal is 239.4.
That’s a lot of weight hanging off the ass end.
I’m sure I can have leafs made; but that’s even more cost.
I want to keep it as short as possible; but it almost seems like fusing two F150 tanks together is the best way to keep it short.
Well I have the tank mounted in the rear, I have have both switched on a Ford fuel selector valve like Kirk mentioned earlier in the thread. It switches while running and everything. Keith's brackets worked perfectly as usual, now I need to get a bumper from him :) If people want I could post a better writeup on how I put it all in, seems like it would be useful for folks that don't want to have jerry cans hanging on all over their rig.
On the subject of the ford tank. Ive probably missed a more simple solution somewhere but I was looking to go with matching higher flow pumps in both tanks and had to make a way to fit the deatchwerks 255lph in there. While I could have just made a bracket to put it on the ford sender I really wanted a return cup so it would starve if climbing a hill. This was my solution.
<a data-flickr-embed="true" href="https://www.flickr.com/photos/14328359@N08/50769913622/in/dateposted-public/" title="IMG_1127"><img src="https://live.staticflickr.com/65535/50769913622_24bf68d712_z.jpg" width="640" height="480" alt="IMG_1127"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/14328359@N08/50769914007/in/dateposted-public/" title="IMG_1123"><img src="https://live.staticflickr.com/65535/50769914007_cc76825d69_z.jpg" width="480" height="640" alt="IMG_1123"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
<a data-flickr-embed="true" href="https://www.flickr.com/photos/14328359@N08/50769797911/in/dateposted-public/" title="IMG_1124"><img src="https://live.staticflickr.com/65535/50769797911_9a305293d4_z.jpg" width="480" height="640" alt="IMG_1124"></a><script async src="//embedr.flickr.com/assets/client-code.js" charset="utf-8"></script>
[MENTION=163117]kirkd[/MENTION], I did see that but unfortunately that's well beyond my metal working skills... I'm lucky to have a friend with a welder that is willing to work for beer to get the brackets in.
Good luck finding my 4Runner, seems like there's a million silver SR5s on the roads still :)
Collecting parts to do this mod and was wondering if the tank kit should have included something that goes in this hole (circled in red). Ordered the spectra F1G1FA off amazon. If not are you supposed to put a rubber plug there or something?
Small check valve with 1/4” line coming off that is for the charcoal canister. I teed it into the one for my existing tank.
These things? Your tank came with this or you had to buy separate?
Ford Fuel Vapor Valve E7DZ-9B593-A replaced D6AZ-9B593-A and E2AZ-9B593-A Fits most Fords 1971-1989 Amazon.com: Ford Fuel Vapor Valve E7DZ-9B593-A replaced D6AZ-9B593-A and E2AZ-9B593-A Fits most Fords 1971-1989: Automotive
Ford F6TZ-9B076-AA Fuel Vapor Valve Seal Amazon.com: Ford F6TZ-9B076-AA Fuel Vapor Valve Seal: Automotive
I wonder how much interest there would be in a built-out kit that you just need to plumb and bolt up and how much one would need to charge a customer to make it worthwhile? Could it be done without posing liability or other regulation issues?
I would personally love a kit that included everything but the tank. The tanks are so cheap on Amazon or EBAY that it wouldn't be worth your time to bother.
But a complete fuel pump, wiring, hoses, filler neck, etc would be a killer kit. It would have to be under 300 bucks for all those parts I think to make it worth it.
Has anyone found another source for the upper tank mounts aside from bronco graveyard as it seems they are sold out and doesn’t seem like they will restock it.. found a few similar looking ones on Amazon but none say they are compatible with a 79 f150..
Are you referring to the straps that go on top of the tank?
Ambrose67
